specialforces27 Posted October 28, 2008 Posted October 28, 2008 I have a quick question. I recently switched to autoCAD 2007 and for some reason it seems as if my double click is disabled, i.e. I can't double click to enter the dynamic block editor, edit text, etc. Is there a setting im unaware of, or has anyone else had this problem? Thanks! Quote
mugshot Posted October 28, 2008 Posted October 28, 2008 try option>user preferences> double click editing Quote
nocturne00 Posted October 28, 2008 Posted October 28, 2008 a system variable. you could also toggle it by inputting DBLCLKEDIT>ON. same as mugshot's advise above only you have to enter options. Quote
specialforces27 Posted October 28, 2008 Author Posted October 28, 2008 I've checked that variable and it is set to ON and it still doesn't work.... any other ideas? Quote
CmdrDuh Posted October 28, 2008 Posted October 28, 2008 check your CUI file for double click actions Quote
rookie37 Posted October 28, 2008 Posted October 28, 2008 I have had a problem as you described. Hopefully your problem isn't as drastic as mine. I tried many things for a week to solve it including dblclkedit to no avail. It turned out the menu was corrupt. I even tried to reload acad but it didn't fix it. (I don't understand why) Something like it won't overwrite your customized menu or something like that. For some reason it wouldn't let me reload the Vanila menu until I; RIGHT CLICK ACAD ICON PROPERTIES TARGET (edit the target to the following) "C:\Program Files\AutoCAD 2008\acad.exe" /p "newprofile" Quote
rookie37 Posted October 28, 2008 Posted October 28, 2008 Before you try as I did, can you log out fo your computer first. Log in again as a different person Start Acad. See if there is still a problem Quote
nocturne00 Posted October 28, 2008 Posted October 28, 2008 I suspect this is another one for the PICKFIRST variable. Set it to "1" Quote
rookie37 Posted October 28, 2008 Posted October 28, 2008 If you edit the icon target, restore it after you open acad or it will start acad afresh each time Quote
specialforces27 Posted October 28, 2008 Author Posted October 28, 2008 PICKFIRST fixed it! Thanks for the replies everyone!!! Quote
