Text is Mirrrored, don't want this
When I insert text with either the TEXT command or MTEXT command, the text is displayed mirrored. This doesn't seem to have anything to do with the MIRRTEXT variable because that is used when I'm actually mirroring the text. In my case, the text is mirrored as soon as I insert it. How can I get it back to normal? Is there a variable I'm missing?
I'm using AutoCAD LT 2012 .
Ok, figured it out. Somehow my UCS was mirrored, therefore mirroring my text. Using the UCS command, I used the 'World' setting and it seemed to fix the issue.
Is the system variable MIRRTEXT set to "1"?
