Difference between reconciled and unreconciled in Autocad
Could someone help me with this. What is this exactly used for.
Thanks
At the top of the AutoCAD screen over to the right, type in RECONCILED and hit the binoculars for help.
This occurs when using xrefs. If a file is xrefed into your drawing and that x ref file has had some new layers created since the last time you opened the "receiving" file , then AutoCAD is simply saying "hey , these layers were not here before" .
The xref manager will group such layers together into a filter. So select all , right click and pick "reconcile layers" .
