Linking a block to an icon?
Hi guys,
Been a while since I was here.
I was wondering if I can link autocad blocks to icons so that I can click the icon and the block will come in, all I would have to do is place the block. I realise you can create tool paletts via design centre but I wanted to create an icon bar with blocks on for my own use.
Hope that makes sense - any ideas?
you can. you need to assign INSERT; etc. to the toolbar button but tbh its so easy creating a palette I wouldn't bother.
Why dont you set the block within the tool pallet?
Hi mate,
Cheers for the reply. However, when I wet up a toolbar button like you say it then waits for a user input. I want the block to come in as soon as I click on the icon.
Two set of inputs would surely have to apply;
1) The location of the block on my harddrive
2) The name of the block
Hope that makes more sense :-)
Because I want to create flyouts. For example, I want a conduit toolbar, I want it to flyout and show all the different sizes - 20mm, 25mm, 30mm etc.
If I do this on a palette I end up having to scroll down and it is a really slow process.
or use dynamic blocks?
Hi mate,
the problem you have doing it off an icon is that you don't get the "ghost" image of where you want to drop the block (another plus in using palettes). I did once see a work around but was too complicated for me.
The location can be part of the block name, something like...
INSERT;"C:/myBlocks/Block1";pause;1;1;1;1
you may need forward slashes instead of backslash - I can't remember the format for buttons
because this will take me longer to set up - hence more hours, hence more money ;-)
Cheers,
I tried this but when I click the icon the insert dialogue block keeps popping up. I can design a control circuit but I'm not very good at macro's I'm afraid :-/
use -INSERT instead of INSERT (subtle difference but a good one)
That's spot on!
Thank you very much for your time. One last thing though and I will leave you alone ;-)
Is there anyway I can specify the insert point when the block comes in? At the moment I have block called 'conduit' in that block is an exploded conduit length. When I bring this 'conduit' block in, the insert point if not actually on the block if that makes sense, it's in 'fresh air'
EDIT: Just though, the insert point needs to be on 0,0 does it not?
*checks
EDIT: Sorted! It is 0,0 *bangs head on desk
Cheers guys, I may set it all up this week, then decide on Palettes, next week and get some more cash!
You can.
Create a palette
browse to the .png you created
open in paint
Add this to your new toolbar.
I know this seems like a long way around but it shows it can be done.
by ghost image, I meant one that hangs off the end of your cross hairs. You don't (at least a long time back when I last tried) get this if inserting from a macro, but you do from the command line and you do from a palette.
Thinking about you fly-out, you can use multiple tabs on your palette - one for each conduit type.
And a pet hate of mine is how it is so easy these days to create blocks with inapproriate insertion points.
