Hi guys
I've got a bit of an issue. I want to inherit the color from one layer to a new created one. For example:
NewLayer.color = OldLayer.color
Evidently that doesn't work. All examples on the net start from known info regarding the color. They just fill the RGB-colors in. That's a bit stupid, because you can use the code for 1 occasion. Duh!
Thanks for the help.
Arnout
Something like this would help
Option Explicit
Sub colorfrom()
Dim oLay As AcadLayer
Dim curLay As AcadLayer
Set curLay = ThisDrawing.Layers("OldOne")
Set oLay = ThisDrawing.Layers.Add("NewOne")
oLay.TrueColor = curLay.TrueColor
End Sub
~'J'~
Yeah, I tried something like that. Here's my code. Everything works except for the color...
sub N_Layer()
Dim aEnt As AcadEntity
Dim aLayer1, aLayer2 As AcadLayer
Dim aSSet As AcadSelectionSet
Dim strLayerName  As String
On Error GoTo Delete
Set aSSet = ThisDrawing.SelectionSets.Add("sset")
aSSet.SelectOnScreen
For Each aEnt In aSSet
    aLayer1 = aEnt.Layer
    strLayerName = "N_" & aLayer1
    Set aLayer2 = ThisDrawing.Layers.Add(strLayerName)
    aEnt.Layer = "N_" & aLayer1
    aEnt.Update
    aLayer2.Lineweight = acLnWt030
    aLayer2.TrueColor = aLayer1.TrueColor
Next
ThisDrawing.SelectionSets.Item("sset").Delete
Exit Sub
Delete:
End Sub
Ah, got it! I went over it, and realised that alayer1 wasn't defined properly. The for-loop should be:
           strLayerName = aEnt.Layer
           Set aLayer1 = ThisDrawing.Layers(strLayerName)
           If strLayerName Like "D_*" Then
               MsgBox "Object reeds in D_-layer", vbOKOnly, "Fout Object"
           ElseIf strLayerName Like "N_*" Then
               MsgBox "Object in N_-layer", vbOKOnly, "Fout Object"
           ElseIf strLayerName Like "E_*" Then
               MsgBox "Object in de Edge", vbOKOnly, "Fout Object"
           Else
               strLayerName = "N_" & strLayerName
               aEnt.Layer = strLayerName
               aEnt.Update
           End If
   Next
