laranjo123 Posted April 15, 2012 Share Posted April 15, 2012 Ahm i wanted to render the interior parts of the yacht. Do i have to scale my 3D? And make it Big enough to zoom in... Quote Link to comment Share on other sites More sharing options...
mugshot Posted April 16, 2012 Share Posted April 16, 2012 correct me if im wrong but it still be depending on camera lens. . . if you use 32, 40, 50 etc. ? Quote Link to comment Share on other sites More sharing options...
tzframpton Posted April 16, 2012 Share Posted April 16, 2012 I use 3DWALK to "navigate" through a model to set my Modelspace Views: http://exchange.autodesk.com/autocad/enu/online-help/search#WS1a9193826455f5ffa23ce210c4a30acaf-519b.htm This will allow you to easily set up any perspective angle you want to render from. Quote Link to comment Share on other sites More sharing options...
sunji_lacsi Posted April 18, 2012 Share Posted April 18, 2012 i used to render valve chambers which are not that spaceous. I just use CAMERA then position it facing toward the target. adjust to your desired setting. (e.g. lens, filed of view. etc) Quote Link to comment Share on other sites More sharing options...
