hello people. . .
just a simple question. . . . how can i have a result of neon effect. . . what material should i use and how high is my intensity factor for the light?
thank you in advance. .
you can use luminous glass from the meterial browser and play with the resulting color by editing it. your intensity would depend on your room size or if there be other lights being used.
where i could find luminous glass?
we only have solid glass from there, luminous galss is not available, under glazing its redlectance and sheet of glass. . . luminousity. . .
find it. . . i cant find the self illumination unless get a default material. . say. . frosted. . . then edit. . . thats it. . . thanks.
