Is there a way to determine as to what object the dimension is "associated" with?
;; Dimension Associations  -  Lee Mac
;; Returns a list of enames associated with an Associative Dimension
(defun LM:DimAssociations ( ent / _massoc )
   (defun _massoc ( key lst / pair )
       (if (setq pair (assoc key lst))
           (cons (cdr pair) (_massoc key (cdr (member pair lst))))
   (if
       (and
           (setq ent (entget ent))
           (wcmatch  (cdr (assoc 0 ent)) "*DIMENSION")
           (setq ent (cdr (assoc 360 (member '(102 . "{ACAD_XDICTIONARY") ent))))
           (setq ent (dictsearch ent "ACAD_DIMASSOC"))
       (_massoc 331 ent)
I think , if the following dxf code is available within the dimension built-in codes . ( maybe ):unsure:
(102 . "{ACAD_REACTORS")
This worked for me .... :)
(defun c:AssocDims (/ s ss i sn e)
 (setq s (ssadd))
 (if (setq ss (ssget "_x" '((0 . "*DIMENSION"))))
     (setq sn (ssname ss (setq i (1- i))))
     (if (member '(102 . "{ACAD_REACTORS") (entget sn))
       (ssadd sn s)
 (if (> (sslength s) 0)
   (print (strcat "You have :"
                  (itoa (sslength s))
                  "Associative Dimsneions "
I'll have a look-see at your code later Tharwat. However, you can directly include that on the ssget filter
Thanks nonetheless :)
That's all my idea is about .:thumbsup:
And Lee as always brings the perfect solution .
Regards
