Ty520 Posted April 17, 2012 Share Posted April 17, 2012 I recently began working for a landscape architect who doesn't know very much about using AutoCAD, and hired someone to create his page templates, line standards, etc. Recently, we have encountered a new problem with page templates in which there are a couple unclickable text blocks within the title block template - it is as if these items don't really exist. Info I am aware of: Each item within the template is on the same layer, but only a couple items behave this way. The template is not comprised of dynamic blocks - just text Quote Link to comment Share on other sites More sharing options...
MSasu Posted April 17, 2012 Share Posted April 17, 2012 Is this behaviour happens in Model or a Layout tab? Quote Link to comment Share on other sites More sharing options...
halfcracked Posted April 17, 2012 Share Posted April 17, 2012 are you sure those are text entities? could they be locked attributes in a block? Quote Link to comment Share on other sites More sharing options...
RobDraw Posted April 17, 2012 Share Posted April 17, 2012 Is layer "0" on and thawed? Quote Link to comment Share on other sites More sharing options...
Ty520 Posted April 17, 2012 Author Share Posted April 17, 2012 the template is in paper space. All layers are on and thawed. Can't check the properties of the text black because it cannot be manipulated in any way. Quote Link to comment Share on other sites More sharing options...
MSasu Posted April 17, 2012 Share Posted April 17, 2012 Please switch to Model Space tab and check if those trouble-maker text entities aren't in fact located there. Quote Link to comment Share on other sites More sharing options...
CyberAngel Posted April 17, 2012 Share Posted April 17, 2012 Is it possible that the text is a company letterhead, an image that's been xrefed into the drawing? If TFrames is off, that would explain why you can't select it. Quote Link to comment Share on other sites More sharing options...
Ty520 Posted April 17, 2012 Author Share Posted April 17, 2012 the object is not an image, and it is not in model space Quote Link to comment Share on other sites More sharing options...
ReMark Posted April 17, 2012 Share Posted April 17, 2012 How about you attach a copy of the DWG file here so we can take a look at it ourselves? Quote Link to comment Share on other sites More sharing options...
Ty520 Posted April 17, 2012 Author Share Posted April 17, 2012 I'll attach a copy if I get permission Quote Link to comment Share on other sites More sharing options...
Dadgad Posted April 18, 2012 Share Posted April 18, 2012 (edited) How do you know it is not an image, without knowing what it is? An image doesn't necessarily mean a photograph or drawing, an image can be text based too. I am thinking that CyberAngel may be on the right track here. Try setting your FRAMESELECTION variable to '1' at the commandline. If that doesn't do it, then try setting your PREVIEWFILTER variable to '0' at the commandline. Edited April 18, 2012 by Dadgad Quote Link to comment Share on other sites More sharing options...
ReMark Posted April 18, 2012 Share Posted April 18, 2012 So, where is that drawing file? An "image" doesn't do us any good as far as troubleshooting the problem goes. A drawing file is what we need. If the file is too big then either zip it or cull out all unnecessary content and do a "saveas" to a new file name then attach that drawing instead. Quote Link to comment Share on other sites More sharing options...
Ty520 Posted April 18, 2012 Author Share Posted April 18, 2012 so after getting back to work today, I began messing around with the file. Using "Control + A" did select the text blocks, verifying that they were being read as an entity by AutoCAD. At that point, it would allow me to click on a handle and manipulate it - after I've clicked on the block after selecting it via "control +A" I can continue to manipulate it like any text block without issue. Quote Link to comment Share on other sites More sharing options...
Ty520 Posted April 18, 2012 Author Share Posted April 18, 2012 EDIT: After experimenting with the template, I have realized that the text block will become unselectable once again if I go to another layout tab and return to the layout where the issue is occuring - the text block occurs on all of the other layout tabs without issue. If I receive permission from my employer to attach the template later, I will add an update so after getting back to work today, I began messing around with the file. Using "Control + A" did select the text blocks, verifying that they were being read as an entity by AutoCAD. At that point, it would allow me to click on a handle and manipulate it - after I've clicked on the block after selecting it via "control +A" I can continue to manipulate it like any text block without issue. Quote Link to comment Share on other sites More sharing options...
Ty520 Posted April 18, 2012 Author Share Posted April 18, 2012 PREVIEWFILTER and FRAMESELECTION do not appear to be valid in AutoCAD 2005 Quote Link to comment Share on other sites More sharing options...
Dadgad Posted April 19, 2012 Share Posted April 19, 2012 Your profile indicates that you are using 2009? What file format is this drawing? Quote Link to comment Share on other sites More sharing options...
Ty520 Posted April 19, 2012 Author Share Posted April 19, 2012 I use 2009 - my employer is on 2005 Quote Link to comment Share on other sites More sharing options...
ReMark Posted April 19, 2012 Share Posted April 19, 2012 I've grown a beard waiting for you to post the file. Please attach a drawing before the beard reaches the floor. Thanks. Quote Link to comment Share on other sites More sharing options...
