LAD152 Posted October 28, 2008 Posted October 28, 2008 I have a few dashed lines in model space, when I switch over and print...the lines are not dashed. Please help!! Quote
Skeeps Posted October 28, 2008 Posted October 28, 2008 Try 'psltscale' in paperspace and change it to 0 or 1 save the drawing then go back into it. Quote
rustysilo Posted October 28, 2008 Posted October 28, 2008 Best to set LTSCALE to 1 and PSLTSCALE to 1 so that your linetypes will display properly in your viewports. Quote
LAD152 Posted October 28, 2008 Author Posted October 28, 2008 You all are the best. Thanks very much! Quote
Skeeps Posted October 28, 2008 Posted October 28, 2008 I always save it and go back in sometimes when I've done this in the past a 'regen' dosen't work. I wander if that's a bug? It happened when I was using Autocad 2004 LT Quote
LS10 Posted October 28, 2008 Posted October 28, 2008 try typing regenall in paper space, that usually sorts it. Quote
