scottish-lawd Posted August 10, 2006 Share Posted August 10, 2006 Ok people this is my first post and I have had a read through the site, I'm currently looking for a program which allows you via pull down menu to select a steel section (British) I used to have one at my last place of work which saved mega time and effort. It was called Turbo steel and basically it inserted the section of your choice to scale. If anyone out there has a similar menufile could you please post it for myself and the rest of the members. Thank you Scottish-lawd Quote Link to comment Share on other sites More sharing options...
pefi Posted August 14, 2006 Share Posted August 14, 2006 Maybe by chance it's that: http://www.draftsperson.net/index.php?title=Free_AutoCAD_Programs_and_Lisp_routines If it's that you can try to help here http://cadtutor.net/forum/viewtopic.php?t=8973 Przemo Quote Link to comment Share on other sites More sharing options...
Spacepig Posted August 14, 2006 Share Posted August 14, 2006 Hi Scottish-lawd... You're in luck - I'm not often on this site any more, but I do have what you're looking for...you'll need three files - here's the first (defun C:STEELS (/ SIZA dcl_id) (initerr) (setq userclick1 T) (setvar "OSMODE" 0) (setvar "CMDECHO" 0) (setq SIZA "UBEAM") (setq dcl_id (load_dialog "steels.dcl")) (if (not (new_dialog "steels" dcl_id)) (exit) ) (setq w (dimx_tile "im") h (dimy_tile "im")) (start_image "im") (fill_image 0 0 w h 5) (setq w1 (/ w 2)) (setq h1 (/ h 2)) (vector_image 0 h w1 0 2) (vector_image w1 0 w h 2) (vector_image 0 h w1 h1 2) (vector_image w1 h1 w h 2) (end_image) (action_tile "UB" "(setq SIZA \"UBEAM\")" ) (action_tile "UC" "(setq SIZA \"UCOLUM\")" ) (action_tile "JO" "(setq SIZA \"JOIST\")" ) (action_tile "TFC" "(setq SIZA \"CHAN\")" ) (action_tile "PFC" "(setq SIZA \"PCHAN\")" ) (action_tile "ELA" "(setq SIZA \"RSA\")" ) (action_tile "ULA" "(setq SIZA \"URSA\")" ) (action_tile "RCR" "(setq SIZA \"SHOLL\")" ) (action_tile "CCR" "(setq SIZA \"CHOLL\")" ) (action_tile "cancel" "(done_dialog)(setq userclick nil)" ) (action_tile "accept" "(done_dialog) (setq userclick T)" ) (start_dialog) (unload_dialog dcl_id) (if userclick (progn (if (eq SIZA "UBEAM") (UBEAM) ) (if (eq SIZA "UCOLUM") (UCOLUM) ) (if (eq SIZA "JOIST") (JOIST) ) (if (eq SIZA "CHAN") (CHAN) ) (if (eq SIZA "CHOLL") (CHOLL) ) (if (eq SIZA "RSA") (RSA) ) (if (eq SIZA "URSA") (URSA) ) (if (eq SIZA "SHOLL") (SHOLL) ) (if (eq SIZA "PCHAN") (PCHAN) ) ) ;progn ) ;if (reset) (if (= userclick1 nil) (c:steels) ); (princ) ) ;defun ;* (defun UBEAM (/ SIZA size file fp item data maxs count chrct numb dlist X Y Z IP P1 P2 P3 P4 P5 P6 P7 P8 P9 P10 P11 P12 P13 P14 P15 P16 P17 P18 P19 P20 P21 NAMES ) ;;;*--------------------------------------------------------- ;;;*CONVERT TO RADIANS (setq X (* pi (/ 90.0 180.0)) Y pi Z (* pi (/ 270.0 180.0)) ) ;setq ;;;*---------------------------------------------------------- ;;;*INITIALISE (setvar "CMDECHO" 0) (setq NAMES '("127x76x13" "152x89x16" "178x102x19" "203x102x23" "203x133x25" "203x133x30" "254x102x22" "254x102x25" "254x102.28" "254x146x31" "254x146x37" "254x146x43" "305x102x25" "305x102x28" "305x102x33" "305x127x37" "305x127x42" "305x127x48" "305x165x40" "305x165x46" "305x165x54" "356x127x33" "356x127x39" "356x171x45" "356x171x51" "356x171x57" "356x171x67" "406x140.39" "406x140x46" "406x178x54" "406x178x60" "406x178x67" "406x178x74" "457x152x52" "457x152x60" "457x152x67" "457x152x74" "457x152x82" "457x191x67" "457x191x74" "457x191x82" "457x191x89" "457x191x98" "533x210x82" "533x210x92" "533x210x101" "533x210x109" "533x210x122" "610x229x101" "610x229x113" "610x229x125" "610x229x140" "610x305x149" "610x305x179" "610x305x238" "686x254x125" "686x254x140" "686x254x152" "686x254x170" "762x267x134" "762x267x147" "762x267x173" "762x267x197" "838x292x176" "838x292x194" "838x292x226" "914x305x201" "914x305x224" "914x305x253" "914x305x289" "914x419x343" "914x419x388" "1016x305x222" "1016x305x249" "1016x305x272" "1016x305x314" "1016x305x349" "1016x305x393" "1016x305x437" "1016x305x487" ) ) (setq dcl_id (load_dialog "steels.dcl")) (if (not (new_dialog "ubeam" dcl_id)) (exit) ) (start_list "selections") (mapcar 'add_list NAMES) (end_list) (action_tile "cancel" "(done_dialog) (setq userclick1 nil)" ) (action_tile "accept" (strcat "(progn (setq SIZA (atof (get_tile \"selections\")))" "(done_dialog) (setq userclick1 T))" ) ) (start_dialog) (unload_dialog dcl_id) (if userclick1 (progn (setq SIZA (fix SIZA)) (setq SIZA (nth SIZA NAMES)) (grab) ;;;*THIS ROUTINE DRAWS A UNIVERSAL BEAM. (mapcar 'set '(H B T1 T2 R1) dlist) (setvar "OSMODE" OLDSNAP) (while (setq IP (getpoint "\nInsertion Point: ")) (setvar "OSMODE" 0) (setq P1 (polar IP 0 (/ T1 2)) P2 (polar P1 X (/ (- H (+ T2 T2 R1 R1)) 2)) P3 (polar P2 X R1) P4 (polar P3 0 R1) P5 (polar P4 0 (/ (- B (+ T1 R1 R1)) 2)) P6 (polar P5 X T2) P7 (polar P6 Y B) P8 (polar P7 Z T2) P9 (polar P8 0 (/ (- B (+ T1 R1 R1)) 2)) P10 (polar P9 0 R1) P11 (polar P10 Z R1) P12 (polar P11 Z (- H (+ T2 T2 R1 R1))) P13 (polar P12 Z R1) P14 (polar P13 Y R1) P15 (polar P14 Y (/ (- B (+ T1 R1 R1)) 2)) P16 (polar P15 Z T2) P17 (polar P16 0 B) P18 (polar P17 X T2) P19 (polar P18 Y (/ (- B (+ T1 R1 R1)) 2)) P20 (polar P19 Y R1) P21 (polar P20 X R1) ) ;setq (command "PLINE" P1 "W" "0.0" "0.0" P2 "ARC" P4 "LINE" P5 P6 P7 P8 P9 "ARC" P11 "LINE" P12 "ARC" P14 "LINE" P15 P16 P17 P18 P19 "ARC" P21 "LINE" P1 "" ) ;command (prompt "\nRotation Angle: ") (command "ROTATE" "LAST" "" IP pause );command (setvar "OSMODE" OLDSNAP) );while ;;;*--------------------------------------------------------- ) ;progn ) ;if (princ) ) ;defun UBEAM (defun UCOLUM (/ SIZA size file fp item data maxs count chrct numb dlist X Y Z IP P1 P2 P3 P4 P5 P6 P7 P8 P9 P10 P11 P12 P13 P14 P15 P16 P17 P18 P19 P20 P21 NAMES ) ;;;*--------------------------------------------------------- ;;;*CONVERT TO RADIANS (setq X (* pi (/ 90.0 180.0)) Y pi Z (* pi (/ 270.0 180.0)) ) ;setq ;;;*---------------------------------------------------------- ;;;*INITIALISE (setvar "CMDECHO" 0) (setq NAMES '("152x152x23" "152x152x30" "152x152x37" "203x203x46" "203x203x52" "203x203x60" "203x203x72" "203x203x86" "254x254x73" "254x254x89" "254x254x107" "254x254x132" "254x254x167" "305x305x97" "305x305x118" "305x305x137" "305x305x158" "305x305x198" "305x305x240" "305x305x283" ) ) (setq dcl_id (load_dialog "steels.dcl")) (if (not (new_dialog "ucolum" dcl_id)) (exit) ) (start_list "selections") (mapcar 'add_list NAMES) (end_list) (action_tile "cancel" "(done_dialog) (setq userclick1 nil)" ) (action_tile "accept" (strcat "(progn (setq SIZA (atof (get_tile \"selections\")))" " (done_dialog)(setq userclick1 T))" ) ) (start_dialog) (unload_dialog dcl_id) (if userclick1 (progn (setq SIZA (fix SIZA)) (setq SIZA (nth SIZA NAMES)) (grab) ;;;*THIS ROUTINE DRAWS A UNIVERSAL COLUMN. (mapcar 'set '(H B T1 T2 R1) dlist) (setvar "OSMODE" OLDSNAP) (while (setq IP (getpoint "\nInsertion Point: ")) (setvar "OSMODE" 0) (setq P1 (polar IP 0 (/ T1 2)) P2 (polar P1 X (/ (- H (+ T2 T2 R1 R1)) 2)) P3 (polar P2 X R1) P4 (polar P3 0 R1) P5 (polar P4 0 (/ (- B (+ T1 R1 R1)) 2)) P6 (polar P5 X T2) P7 (polar P6 Y B) P8 (polar P7 Z T2) P9 (polar P8 0 (/ (- B (+ T1 R1 R1)) 2)) P10 (polar P9 0 R1) P11 (polar P10 Z R1) P12 (polar P11 Z (- H (+ T2 T2 R1 R1))) P13 (polar P12 Z R1) P14 (polar P13 Y R1) P15 (polar P14 Y (/ (- B (+ T1 R1 R1)) 2)) P16 (polar P15 Z T2) P17 (polar P16 0 B) P18 (polar P17 X T2) P19 (polar P18 Y (/ (- B (+ T1 R1 R1)) 2)) P20 (polar P19 Y R1) P21 (polar P20 X R1) ) ;setq (command "PLINE" P1 "W" "0.0" "0.0" P2 "ARC" P4 "LINE" P5 P6 P7 P8 P9 "ARC" P11 "LINE" P12 "ARC" P14 "LINE" P15 P16 P17 P18 P19 "ARC" P21 "LINE" P1 "" ) ;command (prompt "\nRotation Angle: ") (command "ROTATE" "LAST" "" IP pause ) ;command (setvar "OSMODE" OLDSNAP) );while ;;;*--------------------------------------------------------- ) ;progn ) ;if (princ) ) ;defun UCOLUM (defun CHAN (/ SIZA size file fp item data maxs count chrct numb dlist X Y Z IP P1 P2 P3 P4 P5 P6 P7 P8 P9 P10 P11 P15 P16 P17 H1 H2 H3 H4 H5 B1 B2 B3 B4 NAMES ) ;;;*--------------------------------------------------------- ;;;*CONVERT TO RADIANS (setq X (* pi (/ 90.0 180.0)) Y pi Z (* pi (/ 270.0 180.0)) ) ;setq ;;;*---------------------------------------------------------- ;;;*INITIALISE (setvar "CMDECHO" 0) (setq NAMES '("100x50x11" "120x55x13" "140x60x16" "160x65x19" "180x70x22" "200x75x25" "220x80x29" "240x85x32" "260x90x38" "300x100x46" "76x38x7" "127x64x15" "152x76x18" "178x54x15" "381x102x55" ) ) (setq dcl_id (load_dialog "steels.dcl")) (if (not (new_dialog "chan" dcl_id)) (exit) ) (start_list "selections") (mapcar 'add_list NAMES) (end_list) (action_tile "cancel" "(done_dialog) (setq userclick1 nil)" ) (action_tile "accept" (strcat "(progn (setq SIZA (atof (get_tile \"selections\")))" " (done_dialog)(setq userclick1 T))" ) ) (start_dialog) (unload_dialog dcl_id) (if userclick1 (progn (setq SIZA (fix SIZA)) (setq SIZA (nth SIZA NAMES)) (grab) ;;;*THIS ROUTINE DRAWS A TAPERED FLANGE CHANNEL. ;;;* (mapcar 'set '(H B H1 H2 H3 H4 H5 B1 B2 B3 B4) dlist) (setvar "OSMODE" OLDSNAP) (while (setq IP (getpoint "\nInsertion Point: ")) (setvar "OSMODE" 0) (setq P1 (polar IP Z H) P2 (polar P1 0 B) P3 (polar P2 X H1) P4 (polar P3 X H2) P5 (polar P4 Y B4) P6 (polar P5 Y B3) P7 (polar P6 X H3) P8 (polar P7 Y B2) P9 (polar P8 X H4) P10 (polar P9 X H5) P11 (polar P10 X H4) P12 (polar P11 0 B2) P13 (polar P12 X H3) P14 (polar P13 0 B3) P15 (polar P14 0 B4) P16 (polar P15 X H2) P17 (polar P16 X H1) ) ;setq (command "PLINE" IP "W" "0.0" "0.0" P1 P2 P3 "ARC" P5 "LINE" P7 "ARC" P9 "LINE" P10 "ARC" P12 "LINE" P14 "ARC" P16 "LINE" P17 "Close" ) ;command (prompt "\nRotation Angle: ") (command "ROTATE" "LAST" "" IP pause ) ;command (setvar "OSMODE" OLDSNAP) );while ;;;*--------------------------------------------------------- ) ;progn ) ;if (princ) ) ;defun CHAN (defun CHOLL (/ D D1 IP) (setvar "CMDECHO" 0) (setvar "OSMODE" OLDSNAP) (initget 1) (setq IP (getpoint "\nInsertion Point: ") D (getreal "\nOutside Diameter: ") D1 (getreal "\nInside Diameter: ") D (/ D 2) D1 (/ D1 2) ) ;setq (setvar "OSMODE" 0) (command "CIRCLE" IP D "CIRCLE" IP D1 ) ;command (princ) ) (defun RSA (/ SIZA fp size file item data maxs count chrct numb dlist A C IP P1 P2 P3 P4 P5 P6 P7 P8 P9 P10 P11 NAMES ) ;;;*--------------------------------------------------------- ;;;*CONVERT TO RADIANS (setq A (* pi (/ 90.0 180.0)) C pi ) ;setq ;;;*---------------------------------------------------------- ;;;*INITIALISE (setvar "CMDECHO" 0) (setq NAMES '("25x25x3" "25x25x5" "30x30x3" "30x30x5" "40x40x3" "40x40x5" "40x40x6" "45x45x3" "45x45x5" "45x45x6" "50x50x5" "50x50x6" "50x50x8" "60x60x5" "60x60x6" "60x60x8" "60x60x10" "70x70x6" "70x70x8" "70x70x10" "80x80x6" "80x80x8" "80x80x10" "80x80x12" "90x90x8" "90x90x10" "90x90x12" "100x100x8" "100x100x10" "100x100x12" "100x100x15" "120x120x10" "120x120x12" "120x120x15" "150x150x12" "150x150x15" "150x150x18" "200x200x16" "200x200x18" "200x200x20" "200x200x24" ) ) (setq dcl_id (load_dialog "steels.dcl")) (if (not (new_dialog "rsa" dcl_id)) (exit) ) (start_list "selections") (mapcar 'add_list NAMES) (end_list) (action_tile "cancel" "(done_dialog) (setq userclick1 nil)" ) (action_tile "accept" (strcat "(progn (setq SIZA (atof (get_tile \"selections\")))" " (done_dialog)(setq userclick1 T))" ) ) (start_dialog) (unload_dialog dcl_id) (if userclick1 (progn (setq SIZA (fix SIZA)) (setq SIZA (nth SIZA NAMES)) (grab) ;;;*THIS ROUTINE DRAWS A ROLLED STEEL ANGLE. (mapcar 'set '(H B T1 R1 R2) dlist) (setvar "OSMODE" OLDSNAP) (while (setq IP (getpoint "\nInsertion Point: ")) (setvar "OSMODE" 0) (setq P1 (polar IP 0 B) P2 (polar P1 A (- T1 R2)) P3 (polar P2 A R2) P4 (polar P3 C R2) P5 (polar P4 C (- B (+ T1 R1 R2))) P6 (polar P5 C R1) P7 (polar P6 A R1) P8 (polar P7 A (- H (+ T1 R1 R2))) P9 (polar P8 A R2) P10 (polar P9 C R2) P11 (polar P10 C (- T1 R2)) ) ;setq (command "PLINE" IP "W" "0.0" "" P1 P2 "ARC" P4 "LINE" P5 "ARC" P7 "LINE" P8 "ARC" P10 "LINE" P11 "Close" ) ;command (prompt "\nRotation Angle: ") (command "ROTATE" "LAST" "" IP pause ) ;command (setvar "OSMODE" OLDSNAP) );while ;;;*--------------------------------------------------------- ) ;progn ) ;if (princ) ) ;defun RSA (defun URSA (/ SIZA size file fp item data maxs count chrct numb dlist A C IP P1 P2 P3 P4 P5 P6 P7 P8 P9 P10 P11 NAMES ) ;;;*--------------------------------------------------------- ;;;*CONVERT TO RADIANS (setq A (* pi (/ 90.0 180.0)) C pi ) ;setq ;;;*---------------------------------------------------------- ;;;*INITIALISE (setvar "CMDECHO" 0) (setq NAMES '("65x50x6" "65x50x8" "75x50x6" "75x50x8" "80x60x6" "80x60x8" "90x65x6" "90x65x8" "90x65x10" "100x65x8" "100x65x10" "100x75x6" "100x75x8" "100x75x10" "100x75x12" "125x75x8" "125x75x10" "125x75x12" "150x75x10" "150x75x12" "150x75x15" "150x90x10" "150x90x12" "150x90x15" ) ) (setq dcl_id (load_dialog "steels.dcl")) (if (not (new_dialog "ursa" dcl_id)) (exit) ) (start_list "selections") (mapcar 'add_list NAMES) (end_list) (action_tile "cancel" "(done_dialog) (setq userclick1 nil)" ) (action_tile "accept" (strcat "(progn (setq SIZA (atof (get_tile \"selections\")))" " (done_dialog)(setq userclick1 T))" ) ) (start_dialog) (unload_dialog dcl_id) (if userclick1 (progn (setq SIZA (fix SIZA)) (setq SIZA (nth SIZA NAMES)) (grab) ;;;*THIS ROUTINE DRAWS A ROLLED STEEL ANGLE. (mapcar 'set '(H B T1 R1 R2) dlist) (setvar "OSMODE" OLDSNAP) (while (setq IP (getpoint "\nInsertion Point: ")) (setvar "OSMODE" 0) (setq P1 (polar IP 0 B) P2 (polar P1 A (- T1 R2)) P3 (polar P2 A R2) P4 (polar P3 C R2) P5 (polar P4 C (- B (+ T1 R1 R2))) P6 (polar P5 C R1) P7 (polar P6 A R1) P8 (polar P7 A (- H (+ T1 R1 R2))) P9 (polar P8 A R2) P10 (polar P9 C R2) P11 (polar P10 C (- T1 R2)) ) ;setq (command "PLINE" IP "W" "0.0" "" P1 P2 "ARC" P4 "LINE" P5 "ARC" P7 "LINE" P8 "ARC" P10 "LINE" P11 "Close" ) ;command (prompt "\nRotation Angle: ") (command "ROTATE" "LAST" "" IP pause ) ;command (setvar "OSMODE" OLDSNAP) );while ;;;*--------------------------------------------------------- ) ;progn ) ;if (princ) ) ;defun URSA (defun SHOLL (/ x y z h b t1 r1 r2 h1 b1 p1 p2 p3 p4 p5 p6 p7 p8 p9 p10 p11 p12 p13) (setvar "CMDECHO" 0) (setvar "OSMODE" OLDSNAP) ;;*-------------------------------------------------------- (setq x (* pi (/ 90.0 180.0)) y pi z (* pi (/ 270.0 180.0)) ) ;setq ;;;*------------------------------------------------------- (initget 1) (setq ip (getpoint "\nInsertion Point <Pick Point>: ")) (initget 7) (setq h (getreal "\nHeight of Section <mm>: ")) (initget 7) (setq b (getreal "\nWidth of Section <mm>: ")) (initget 7) (setq t1 (getreal "\nWall Thickness <mm>: ")) (setq r2 (/ t1 2) h1 (- h t1 t1) b1 (- b t1 t1) r1 (+ t1 r2) ) ;setq ;;;*------------------------------------------------------- (setvar "OSMODE" 0) (repeat 2 (setq p1 (polar ip 0 (/ b 2)) p2 (polar p1 x (/ (- h r1 r1) 2)) p3 (polar p2 x r1) p4 (polar p3 y r1) p5 (polar p4 y (- b r1 r1)) p6 (polar p5 y r1) p7 (polar p6 z r1) p8 (polar p7 z (- h r1 r1)) p9 (polar p8 z r1) p10 (polar p9 0 r1) p11 (polar p10 0 (- b r1 r1)) p12 (polar p11 0 r1) p13 (polar p12 x r1) ) ;setq ;;;*-------------------------------------------------------- (command "Pline" p1 "W" "0.0" "0.0" p2 "Arc" p4 "Line" p5 "Arc" p7 "Line" p8 "Arc" p10 "Line" p11 "Arc" p13 "Line" p1 "" ) ;command ;;;*--------------------------------------------------------- (setq h h1 b b1 r1 r2 ) ;setq ;;;*--------------------------------------------------------- ) ;repeat ;;;*---------------------------------------------------------- (princ) ) ;defun (defun JOIST (/ SIZA size file fp item data maxs count chrct numb dlist X Y Z IP P1 P2 P3 P4 P5 P6 P7 P8 P9 P10 P11 P15 P16 P17 P18 P19 P20 P21 P22 P23 P24 P25 P26 P27 P28 P29 P30 P31 P32 P33 H1 H2 H3 H4 H5 B1 B2 B3 B4 ) ;;;*--------------------------------------------------------- ;;;*CONVERT TO RADIANS (setq X (* pi (/ 90.0 180.0)) Y pi Z (* pi (/ 270.0 180.0)) ) ;setq ;;;*---------------------------------------------------------- ;;;*INITIALISE (setvar "CMDECHO" 0) (setq NAMES '("127x76x13" "152x89x17" "178x102x22" "203x102x25" "203x152x52" "254x152x59" "305x152x66" ) ) (setq dcl_id (load_dialog "steels.dcl")) (if (not (new_dialog "joist" dcl_id)) (exit) ) (start_list "selections") (mapcar 'add_list NAMES) (end_list) (action_tile "cancel" "(done_dialog) (setq userclick1 nil)" ) (action_tile "accept" (strcat "(progn (setq SIZA (atof (get_tile \"selections\")))" " (done_dialog)(setq userclick1 T))" ) ) (start_dialog) (unload_dialog dcl_id) (if userclick1 (progn (setq SIZA (fix SIZA)) (setq SIZA (nth SIZA NAMES)) (grab) ;;;*THIS ROUTINE DRAWS A JOIST. (mapcar 'set '(H B H1 H2 H3 H4 H5 B1 B2 B3 B4) dlist) (setvar "OSMODE" OLDSNAP) (while (setq IP (getpoint "\nInsertion Point: ")) (setvar "OSMODE" 0) (setq P1 (polar IP 0 B1) P2 (polar P1 X (/ H5 2)) P3 (polar P2 X H4) P4 (polar P3 0 B2) P5 (polar P4 X H3) P6 (polar P5 0 B3) P7 (polar P6 0 B4) P8 (polar P7 X H2) P9 (polar P8 X H1) P10 (polar P9 Y B) P11 (polar P10 Z H1) P12 (polar P11 Z H2) P13 (polar P12 0 B4) P14 (polar P13 0 B3) P15 (polar P14 Z H3) P16 (polar P15 0 B2) P17 (polar P16 Z H4) P18 (polar P17 Z H5) P19 (polar P18 Z H4) P20 (polar P19 Y B2) P21 (polar P20 Z H3) P22 (polar P21 Y B3) P23 (polar P22 Y B4) P24 (polar P23 Z H2) P25 (polar P24 Z H1) P26 (polar P25 0 B) P27 (polar P26 X H1) P28 (polar P27 X H2) P29 (polar P28 Y B4) P30 (polar P29 Y B3) P31 (polar P30 X H3) P32 (polar P31 Y B2) P33 (polar P32 X H4) ) ;setq (command "PLINE" P1 "W" "0.0" "0.0" P2 "ARC" P4 "LINE" P6 "ARC" P8 "LINE" P9 P10 P11 "ARC" P13 "LINE" P15 "ARC" P17 "LINE" P18 "ARC" P20 "LINE" P22 "ARC" P24 "LINE" P25 P26 P27 "ARC" P29 "LINE" P31 "ARC" P33 "LINE" P1 "" ) ;command (prompt "\nRotation Angle: ") (command "ROTATE" "LAST" "" IP pause ) ;command (setvar "OSMODE" OLDSNAP) );while ;;;*--------------------------------------------------------- ) ;progn ) ;if (princ) ) ;defun JOIST (defun PCHAN (/ SIZA size file fp item data maxs count chrct numb dlist X Y Z IP P1 P2 P3 P4 P5 P6 P7 P8 P9 P10 P11 NAMES ) ;;;*--------------------------------------------------------- ;;;*CONVERT TO RADIANS (setq X (* pi (/ 90.0 180.0)) Y pi Z (* pi (/ 270.0 180.0)) ) ;setq ;;;*---------------------------------------------------------- ;;;*INITIALISE (setvar "CMDECHO" 0) (setq NAMES '("100x50x10" "120x55x13" "140x60x15" "160x65x18" "180x70x21" "200x75x24" "220x80x28" "240x85x32" "260x90x36" "280x95x41" "300x100x45" ) ) (setq dcl_id (load_dialog "steels.dcl")) (if (not (new_dialog "pchan" dcl_id)) (exit) ) (start_list "selections") (mapcar 'add_list NAMES) (end_list) (action_tile "cancel" "(done_dialog) (setq userclick1 nil)" ) (action_tile "accept" (strcat "(progn (setq SIZA (atof (get_tile \"selections\")))" " (done_dialog)(setq userclick1 T))" ) ) (start_dialog) (unload_dialog dcl_id) (if userclick1 (progn (setq SIZA (fix SIZA)) (setq SIZA (nth SIZA NAMES)) (grab) ;;;*THIS ROUTINE DRAWS A PARALLEL FLANGE CHANNEL. (mapcar 'set '(H B T1 T2 R1) dlist) (setvar "OSMODE" OLDSNAP) (while (setq IP (getpoint "\nInsertion Point: ")) (setvar "OSMODE" 0) (setq P1 (polar IP Z H) P2 (polar P1 0 B) P3 (polar P2 X T2) P4 (polar P3 Y (- B (+ R1 T1))) P5 (polar P4 Y R1) P6 (polar P5 X R1) P7 (polar P6 X (- H (+ T2 T2 R1 R1))) P8 (polar P7 X R1) P9 (polar P8 0 R1) P10 (polar P9 0 (- B (+ R1 T1))) P11 (polar P10 X T2) ) ;setq (command "PLINE" IP "W" "0.0" "0.0" P1 P2 P3 P4 "ARC" P6 "LINE" P7 "ARC" P9 "LINE" P10 P11 "Close" ) ;command (prompt "\nRotation Angle: ") (command "ROTATE" "LAST" "" IP pause ) ;command (setvar "OSMODE" OLDSNAP) );while ;;;*--------------------------------------------------------- ) ;progn ) ;if (princ) ) ;defun PCHAN ;;;*FILE & INFORMATION RETRIEVAL ROUTINE. (defun grab () (setq dlist nil size (strcat "*" SIZA) file (findfile "steels.DAT") fp (open file "r") item (read-line fp) ) ;setq (while item (if (= item size) (setq data (read-line fp) item nil ) ;setq (setq item (read-line fp)) ) ;if ) ;while (if data (progn (setq maxs (strlen data) count 1 chrct 1 ) ;setq (while (< count maxs) (if (/= "," (substr data count 1)) (setq chrct (1+ chrct)) (setq numb (atof (substr data (1+ (- count chrct)) chrct)) dlist (append dlist (list numb)) chrct 1 ) ;setq ) ;if (setq count (1+ count)) ) ;while (setq numb (atof (substr data (1+ (- count chrct)))) dlist (append dlist (list numb)) ) ;setq ) ;progn ) ;if data (close fp) ) ;defun ;;;*========================================================== ;;;*========================================================== (defun initerr () (setq oldlayer (getvar "clayer")) (setq oldsnap (getvar "osmode")) (setq oldpick (getvar "pickbox")) (setq temperr *error*) (setq *error* trap) (princ) ) ;defun ;;;*=========================================================== (defun trap (errmsg) (command nil nil nil) (if (not (member errmsg '("console break" "Function Cancelled")) ) (princ (strcat "\nError: " errmsg)) ) ; (setvar "clayer" oldlayer) (setvar "menuecho" 0) (setvar "highlight" 1) (setvar "osmode" oldsnap) (setvar "pickbox" oldpick) (princ "\nError Resetting Enviroment ") (terpri) (setq *error* temperr) (princ) ) ;defun ;;;*=========================================================== (defun reset () (setq *error* temperr) (setvar "clayer" oldlayer) (setvar "menuecho" 0) (setvar "highlight" 1) (setvar "osmode" oldsnap) (setvar "pickbox" oldpick) (princ) ) ;defun ;;;*====================================================== (princ) Quote Link to comment Share on other sites More sharing options...
Spacepig Posted August 14, 2006 Share Posted August 14, 2006 Hi... You need to copy that last file to the clipboard and paste it using notepad into a file called steels.lsp. Here's the code for the second file - it's not as long as the last one steels : dialog { label = "Steel Sections (Metric)"; : boxed_radio_column { label = "Available Sections"; : radio_button { label = "Universal &Beams"; key = "UB"; value = "1"; } : radio_button { label = "Universal &Columns"; key = "UC"; } : radio_button { label = "&Joists"; key = "JO"; } : radio_button { label = "&Tapered Flange Channels"; key = "TFC"; } : radio_button { label = "&Parallel Flange Channels"; key = "PFC"; } : radio_button { label = "&Equal Leg Angles"; key = "ELA"; } : radio_button { label = "U&n-Equal Leg Angles"; key = "ULA"; } : spacer { width = 1;} : radio_button { label = "&Rectangular Cold Rolled"; key = "RCR"; } : radio_button { label = "&Circular Cold Rolled"; key = "CCR"; } : spacer { width = 1;} } ok_cancel ; : row { : image { key = "im" ; height = 1.0 ; width = 4.0 ; } : paragraph { : text_part { label = "Designed and Created"; } : text_part { label = "by AMEC Design and Management"; } } } } ubeam : dialog { label = "U.B's."; : list_box { label = "&Choose Section :"; key = "selections"; height = 12; allow_accept = true ; } ok_cancel ; :text_part { label = "Designed and Created"; } :text_part { label = "by AMEC Design and Management"; } } chan : dialog { label = "R.S.C's."; : list_box { label = "&Choose Section :"; key = "selections"; height = 12; allow_accept = true ; } ok_cancel ; :text_part { label = "Designed and Created"; } :text_part { label = "by AMEC Design and Management"; } } joist : dialog { label = "R.S.J's."; : list_box { label = "&Choose Section :"; key = "selections"; height = 8; allow_accept = true ; } ok_cancel ; :text_part { label = "Designed and Created"; } :text_part { label = "by AMEC Design and Management"; } } pchan : dialog { label = "P.F.C's."; : list_box { label = "&Choose Section :"; key = "selections"; height = 12; allow_accept = true ; } ok_cancel ; :text_part { label = "Designed and Created"; } :text_part { label = "by AMEC Design and Management"; } } rsa : dialog { label = "R.S.A's."; : list_box { label = "&Choose Section :"; key = "selections"; height = 12; allow_accept = true ; } ok_cancel ; :text_part { label = "Designed and Created"; } :text_part { label = "by AMEC Design and Management"; } } ucolum : dialog { label = "U.C's."; : list_box { label = "&Choose Section :"; key = "selections"; height = 12; allow_accept = true ; } ok_cancel ; :text_part { label = "Designed and Created"; } :text_part { label = "by AMEC Design and Management"; } } ursa : dialog { label = "U.R.S.A's."; : list_box { label = "&Choose Section :"; key = "selections"; height = 12; allow_accept = true ; } ok_cancel ; :text_part { label = "Designed and Created"; } :text_part { label = "by AMEC Design and Management"; } } Quote Link to comment Share on other sites More sharing options...
Spacepig Posted August 14, 2006 Share Posted August 14, 2006 And the last file... **TAPERED FLANGE CHANNELS *------------------------------------------------ *100x50x11 100.0,50.0,1.9,4.9,2.5,9.2,63.0,6.0,8.5,31.0,4.5 *120x55x13 120.0,55.0,2.3,4.9,2.8,9.7,80.6,7.0,9.0,34.5,4.5 *140x60x16 140.0,60.0,2.6,5.4,3.1,10.8,96.2,7.0,10.0,38.0,5.0 *160x65x19 160.0,65.0,2.4,6.0,3.3,11.4,113.8,7.5,10.5,41.5,5.5 *180x70x22 180.0,70.0,2.7,6.0,3.7,11.9,131.4,8.0,11.0,45.5,5.5 *200x75x25 200.0,75.0,2.5,6.5,3.9,12.5,149.2,8.5,11.5,49.0,6.0 *220x80x29 220.0,80.0,2.8,7.0,4.2,13.5,165.0,9.0,12.5,52.0,6.5 *240x85x32 240.0,85.0,3.1,7.0,4.5,14.1,182.6,9.5,13.0,56.0,6.5 *260x90x38 260.0,90.0,3.4,7.6,4.8,15.1,198.2,10.0,14.0,59.0,7.0 *300x100x46 300.0,100.0,4.0,8.7,5.3,17.3,229.4,10.0,16.0,66.0,8.0 *-------------------------------------------------- **OLD IMPERIAL TAPERED FLANGE CHANNELS *-------------------------------------------------- *76x38x7 76.0,38.0,2.9,2.6,2.0,8.3,44.4,5.1,7.6,22.9,2.4 *127x64x15 127.0,64.0,4.3,2.6,3.9,11.7,82.0,6.4,10.7,44.5,2.4 *152x76x18 152.0,76.0,6.7,2.6,4.8,13.3,97.2,6.4,12.2,55.0,2.4 *178x54x15 178.0,54.0,4.3,3.3,1.3,8.6,143.0,5.8,8.3,36.7,3.2 *381x102x55 381.0,102.0,6.4,5.2,6.3,16.6,312.0,10.4,15.2,71.6,4.8 *-------------------------------------------------- **PARALLEL FLANGE CHANNELS **H B T1 T2 R1 *-------------------------------------------------- *100x50x10 100.0,50.0,5.0,8.4,8.4 *120x55x13 120.0,55.0,5.5,9.1,9.1 *140x60x15 140.0,60.0,6.0,9.9,9.9 *160x65x18 160.0,65.0,6.5,10.4,10.4 *180x70x21 180.0,70.0,7.0,10.9,10.9 *200x75x24 200.0,75.0,7.5,11.4,11.4 *220x80x28 220.0,80.0,7.9,12.5,12.5 *240x85x32 240.0,85.0,8.4,13.0,13.0 *260x90x36 260.0,90.0,8.8,13.9,13.9 *280x95x41 280.0,95.0,9.2,14.8,14.8 *300x100x45 300.0,100.0,9.6,15.5,15.5 **------------------------------------- **ROLLED STEEL JOISTS DATA **----------------------------------------------- *127x76x13 127.0,76.2,3.6,2.6,2.2,8.6,93.0,2.3,7.9,25.6,2.3 *152x89x17 154.4,88.9,4.1,2.6,2.8,8.6,116.2,2.45,7.9,31.7,2.4 *178x102x22 177.8,102.0,3.7,3.5,3.1,10.3,136.6,2.6,9.4,35.8,3.2 *203x102x25 203.2,101.6,5.1,3.5,3.9,9.4,159.4,2.9,9.4,35.3,3.2 *203x152x52 203.0,152.0,3.8,8.7,6.8,17.8,128.8,4.4,15.5,48.5,7.6 *254x152x59 254.0,152.0,5.3,8.7,6.8,17.8,176.8,4.6,15.5,48.3,7.6 *305x152x66 305.0,152.0,5.5,8.7,6.7,17.8,227.6,5.1,15.5,47.8,7.6 **--------------------------------------------------- **ROLLED STEEL ANGLE DATA **--------------------------- **H X B X T1 X R1 X R2 **--------------------------- *25x25x3 25.0,25.0,3.0,3.5,2.0 *25x25x5 25.0,25.0,5.0,3.5,2.0 *30x30x3 30.0,30.0,3.0,5.0,2.5 *30x30x5 30.0,30.0,5.0,5.0,2.5 *35x35x3 35.0,35.0,3.0,5.0,2.5 *35x35x5 35.0,35.0,5.0,5.0,2.5 *40x40x3 40.0,40.0,3.0,6.0,3.0 *40x40x5 40.0,40.0,5.0,6.0,3.0 *40x40x6 40.0,40.0,6.0,6.0,3.0 *45x45x3 45.0,45.0,3.0,7.0,3.5 *45x45x5 45.0,45.0,5.0,7.0,3.5 *45x45x6 45.0,45.0,6.0,7.0,3.5 *50x50x5 50.0,50.0,5.0,7.0,3.5 *50x50x6 50.0,50.0,6.0,7.0,3.5 *50x50x8 50.0,50.0,8.0,7.0,3.5 *60x60x5 60.0,60.0,5.0,8.0,4.0 *60x60x6 60.0,60.0,6.0,8.0,4.0 *60x60x8 60.0,60.0,8.0,8.0,4.0 *60x60x10 60.0,60.0,10.0,8.0,4.0 *70x70x6 70.0,70.0,6.0,9.0,4.5 *70x70x8 70.0,70.0,8.0,9.0,4.5 *70x70x10 70.0,70.0,10.0,9.0,4.5 *80x80x6 80.0,80.0,6.0,10.0,5.0 *80x80x8 80.0,80.0,8.0,10.0,5.0 *80x80x10 80.0,80.0,10.0,10.0,5.0 *80x80x12 80.0,80.0,12.0,10.0,5.0 *90x90x8 90.0,90.0,8.0,11.0,5.5 *90x90x10 90.0,90.0,10.0,11.0,5.5 *90x90x12 90.0,90.0,12.0,11.0,5.5 *100x100x8 100.0,100.0,8.0,12.0,6.0 *100x100x10 100.0,100.0,10.0,12.0,6.0 *100x100x12 100.0,100.0,12.0,12.0,6.0 *100x100x15 100.0,100.0,15.0,12.0,6.0 *120x120x10 120.0,120.0,10.0,13.0,6.5 *120x120x12 120.0,120.0,12.0,13.0,6.5 *120x120x15 120.0,120.0,15.0,13.0,6.5 *150x150x12 150.0,150.0,12.0,16.0,8.0 *150x150x15 150.0,150.0,15.0,16.0,8.0 *150x150x18 150.0,150.0,18.0,16.0,8.0 *200x200x16 200.0,200.0,16.0,18.0,9.0 *200x200x18 200.0,200.0,18.0,18.0,9.0 *200x200x20 200.0,200.0,20.0,18.0,9.0 *200x200x24 200.0,200.0,24.0,18.0,9.0 **------------------------- **UNIVERSAL BEAMS DATA **----------------------- **H X B X T1 X T2 X R1 **----------------------- *127x76x13 127.0,76.0,4.0,7.6,7.6 *152x89x16 152.4,88.7,4.5,7.7,7.6 *178x102x19 177.8,101.2,4.8,7.9,7.6 *203x102x23 203.2,101.8,5.4,9.3,7.6 *203x133x25 203.2,133.2,5.7,7.8,7.6 *203x133x30 206.8,133.9,6.4,9.6,7.6 *254x102x22 254.0,101.6,5.7,6.8,7.6 *254x102x25 257.2,101.9,6.0,8.4,7.6 *254x102.28 260.4,102.2,6.3,10.0,7.6 *254x146x31 251.4,146.1,6.0,8.6,7.6 *254x146x37 256.0,146.4,6.3,10.9,7.6 *254x146x43 259.6,147.3,7.2,12.7,7.6 *305x102x25 305.1,101.6,5.8,7.0,7.6 *305x102x28 308.7,101.8,6.0,8.8,7.6 *305x102x33 312.7,102.4,6.6,10.8,7.6 *305x127x37 304.4,123.4,7.1,10.7,8.9 *305x127x42 307.2,124.3,8.0,12.1,8.9 *305x127x48 311.0,125.3,9.0,14.0,8.9 *305x165x40 303.4,165.0,6.0,10.2,8.9 *305x165x46 306.6,165.7,6.7,11.8,8.9 *305x165x54 310.4,166.9,7.9,13.7,8.9 *356x127x33 349.0,125.4,6.0,8.5,10.2 *356x127x39 353.4,126.0,6.6,10.7,10.2 *356x171x45 351.4,171.1,7.0,9.7,10.2 *356x171x51 355.0,171.5,7.4,11.5,10.2 *356x171x57 358.0,172.2,8.1,13.0,10.2 *356x171x67 363.4,173.2,9.1,15.7,10.2 *406x140.39 398.0,141.8,6.4,8.6,10.2 *406x140x46 403.2,142.2,6.8,11.2,10.2 *406x178x54 402.6,177.7,7.7,10.9,10.2 *406x178x60 406.4,177.9,7.9,12.8,10.2 *406x178x67 409.4,178.8,8.8,14.3,10.2 *406x178x74 412.8,179.5,9.5,16.0,10.2 *457x152x52 449.8,152.4,7.6,10.9,10.2 *457x152x60 454.6,152.9,8.1,13.3,10.2 *457x152x67 458.0,153.8,9.0,15.0,10.2 *457x152x74 462.0,154.4,9.6,17.0,10.2 *457x152x82 465.8,155.3,10.5,18.9,10.2 *457x191x67 453.4,189.9,8.5,12.7,10.2 *457x191x74 457.0,190.4,9.0,14.5,10.2 *457x191x82 460.0,191.3,9.9,16.0,10.2 *457x191x89 463.4,191.9,10.5,17.7,10.2 *457x191x98 467.2,192.8,11.4,19.6,10.2 *533x210x82 528.3,208.8,9.6,13.2,12.7 *533x210x92 533.1,209.3,10.1,15.6,12.7 *533x210x101 536.7,210.0,10.8,17.4,12.7 *533x210x109 539.5,210.8,11.6,18.8,12.7 *533x210x122 544.5,211.9,12.7,21.3,12.7 *610x229x101 602.6,227.6,10.5,14.8,12.7 *610x229x113 607.6,228.2,11.1,17.3,12.7 *610x229x125 612.2,229.0,11.9,19.6,12.7 *610x229x140 617.2,230.2,13.1,22.1,12.7 *610x305x149 612.4,304.8,11.8,19.7,16.5 *610x305x179 620.2,307.1,14.1,23.6,16.5 *610x305x238 635.8,311.4,18.4,31.4,16.5 *686x254x125 677.9,253.0,11.7,16.2,15.2 *686x254x140 683.5,253.7,12.4,19.0,15.2 *686x254x152 687.5,254.5,13.2,21.0,15.2 *686x254x170 692.9,255.8,14.5,23.7,15.2 *762x267x134 750.0,264.4,12.0,15.5,16.5 *762x267x147 754.0,265.2,12.8,17.5,16.5 *762x267x173 762.2,266.7,14.3,21.6,16.5 *762x267x197 269.8,268.0,15.6,25.4,16.5 *838x292x176 834.9,291.7,14.0,18.8,17.8 *838x292x194 840.7,292.4,14.7,21.7,17.8 *838x292x226 850.9,293.8,16.1,26.8,17.8 *914x305x201 903.0,303.3,15.1,20.2,19.1 *914x305x224 910.4,304.1,15.9,23.9,19.1 *914x305x253 918.4,305.5,17.3,27.9,19.1 *914x305x289 926.6,307.7,19.5,32.0,19.1 *914x419x343 911.8,418.5,19.4,32.0,24.1 *914x419x388 921.0,420.5,21.4,36.6,24.1 *1016x305x222 970.3,300.0,16.0,21.1,30.0 *1016x305x249 980.2,300.0,16.5,26.0,30.0 *1016x305x272 990.1,300.0,16.5,31.0,30.0 *1016x305x314 1000.0,300.0,19.1,35.9,30.0 *1016x305x349 1008.1,302.0,21.1,40.0,30.0 *1016x305x393 1016.0,303.0,24.4,43.9,30.0 *1016x305x437 1025.9,305.4,26.9,49.0,30.0 *1016x305x487 1036.1,308.5,30.0,54.1,30.0 *100x55x8 100.0,55.0,4.1,5.7,7.0 *120x64x10 120.0,64.0,4.4,6.3,7.0 *140x73x13 140.0,73.0,4.7,6.9,7.0 *160x82x16 160.0,82.0,5.0,7.4,9.0 *180x91x19 180.0,91.0,5.3,8.0,9.0 *200x100x22 200.0,100.0,5.6,8.5,12.0 *203x133x25 203.2,133.4,5.8,7.8,7.6 *203x133x30 206.8,133.8,6.3,9.6,7.6 *254x146x31 251.5,146.1,6.1,8.6,7.6 *254x146x37 256.0,146.4,6.4,10.9,7.6 *254x146x43 259.6,147.3,7.3,12.7,7.6 *305x102x25 304.8,101.6,5.8,6.8,7.6 *305x102x29 308.9,101.9,6.1,8.9,7.6 *305x102x33 312.7,102.4,6.6,10.8,7.6 *305x165x41 303.8,165.1,6.1,10.2,8.9 *305x165x46 307.1,165.7,6.7,11.8,8.9 *305x165x54 310.9,166.8,7.7,13.7,8.9 *356x171x45 352.0,171.0,6.9,9.7,10.2 *356x171x51 355.6,171.5,7.3,11.5,10.2 *356x171x57 358.6,172.1,8.0,13.0,10.2 *356x171x67 364.0,173.2,9.1,15.7,10.2 *406x140x39 397.3,141.8,6.3,8.6,10.2 *406x140x46 402.3,142.4,6.9,11.2,10.2 *406x178x54 402.6,177.6,7.6,10.9,10.2 *406x178x60 406.4,177.8,7.8,12.8,10.2 *406x178x67 409.4,178.8,8.8,14.3,10.2 *406x178x75 412.8,179.7,9.7,16.0,10.2 *457x191x67 453.6,189.9,8.5,12.7,10.2 *457x191x75 457.2,190.5,9.1,14.5,10.2 *457x191x82 460.2,191.3,9.9,16.0,10.2 *457x191x90 463.6,192.0,10.6,17.7,10.2 *457x191x98 467.4,192.8,11.4,19.6,10.2 *533x210x82 528.3,208.7,9.6,13.2,12.7 *533x210x93 533.1,209.3,10.2,15.6,12.7 *533x210x101 536.7,210.1,10.9,17.4,12.7 *533x210x109 539.5,210.7,11.6,18.8,12.7 *533x210x122 544.6,211.9,12.8,21.3,12.7 *610x229x101 602.2,227.6,10.6,14.8,12.7 *610x229x113 607.3,228.2,11.2,17.3,12.7 *610x229x125 611.9,229.0,11.9,19.6,12.7 *610x229x140 617.0,230.1,13.1,22.1,12.7 *610x305x149 609.6,304.8,11.9,19.7,16.5 *610x305x179 617.5,307.0,14.1,23.6,16.5 *610x305x238 633.0,311.5,18.6,31.4,16.5 *686x254x125 677.9,253.0,11.7,16.2,15.2 *686x254x140 683.5,253.7,12.4,19.0,15.2 *686x254x152 687.6,254.5,13.2,21.0,15.2 *686x254x170 692.9,255.8,14.5,23.7,15.2 **------------------------- **UNIVERSAL COLUMNS DATA **----------------------- **H X B X T1 X T2 X R1 **----------------------- *152x152x23 152.4,152.4,6.1,6.8,7.6 *152x152x30 157.5,152.9,6.6,9.4,7.6 *152x152x37 161.8,154.4,8.1,11.5,7.6 *203x203x46 203.2,203.2,7.3,11.0,10.2 *203x203x52 206.2,203.9,8.0,12.5,1O.2 *203x203x60 209.6,205.2,9.3,14.2,10.2 *203x203x71 215.9,206.2,10.3,17.3,10.2 *203x203x86 222.3,208.8,13.0,20.5,10.2 *254x254x73 254.0,254.0,8.6,14.2,12.7 *254x254x89 260.4,255.9,10.5,17.3,12.7 *254x254x107 266.7,258.3,13.0,20.5,12.7 *254x254x132 276.4,261.0,15.6,25.1,12.7 *254x254x167 289.1,264.5,19.2,31.7,12.7 *305x305x97 307.8,304.8,9.9,15.4,15.2 *305x305x118 314.5,306.8,11.9,18.7,15.2 *305x305x137 320.5,308.7,13.8,21.7,15.2 *305x305x158 327.2,310.6,15.7,25.0,15.2 *305x305x198 339.9,314.1,19.2,31.4,15.2 *305x305x240 352.6,317.9,23.0,37.7,15.2 *305x305x283 365.3,321.8,26.9,44.1,15.2 **------------------------- **ROLLED STEEL UNEQUAL ANGLES DATA **--------------------------------- **H X B X T1 X R1 X R2 **--------------------------------- *65x50x6 65.0,50.0,6.0,6.0,3.0 *65x50x8 65.0,50.0,8.0,6.0,3.0 *75x50x6 75.0,50.0,6.0,7.0,3.5 *75x50x8 75.0,50.0,8.0,7.0,3.5 *80x60x6 80.0,60.0,6.0,8.0,4.0 *80x60x8 80.0,60.0,8.0,8.0,4.0 *90x65x6 90.0,65.0,6.0,8.0,4.0 *90x65x8 90.0,65.0,8.0,8.0,4.0 *90x65x10 90.0,65.0,10.0,8.0,4.0 *100x65x8 100.0,65.0,8.0,10.0,5.0 *100x65x10 100.0,65.0,10.0,10.0,5.0 *100x75x6 100.0,75.0,6.0,10.0,5.0 *100x75x8 100.0,75.0,8.0,10.0,5.0 *100x75x10 100.0,75.0,10.0,10.0,5.0 *100x75x12 100.0,75.0,12.0,10.0,5.0 *125x75x8 125.0,75.0,8.0,11.0,5.5 *125x75x10 125.0,75.0,10.0,11.0,5.5 *125x75x12 125.0,75.0,12.0,11.0,5.5 *150x75x10 150.0,75.0,10.0,11.0,5.5 *150x75x12 150.0,75.0,12.0,11.0,5.5 *150x75x15 150.0,75.0,15.0,11.0,5.5 *150x90x10 150.0,90.0,10.0,12.0,6.0 *150x90x12 150.0,90.0,12.0,12.0,6.0 *150x90x15 150.0,90.0,15.0,12.0,6.0 **----------------------- Quote Link to comment Share on other sites More sharing options...
Spacepig Posted August 14, 2006 Share Posted August 14, 2006 Hello again... I suppose you want to know how to save and use the files now... As I said - save the code from the first file as steels.lsp Save the code from the second file as steels.dcl Save the code from the third file as steels.dat I use notepad to create the files so you don't get any stray unicode formating messing with the code. When you've got the 3 files created, place them all in the same directory (I use c:\lisps) and make sure that the directory is included in the search file path in Autocad. Type (load "steels.lsp") at the command prompt to load the routine and then type "steels" (without the inverted commas and the dialogue box will come up - the rest should be self explanatory. Feel free to remove the references to Amec in the second file if you want - it's not copywrited. Also the data in the third file is the info you'd get from the corus book - so if there are any updates, have a look at one the the existing sections and you should be able to figure out what order to put them in. Depending on which version of autocad you're using I can show you how to create a line in the pulldown menus to add the command automatically All the best Spacepig Quote Link to comment Share on other sites More sharing options...
scottish-lawd Posted August 19, 2006 Author Share Posted August 19, 2006 Superb Mate just what I needed. Thanks alot mate well appreciated. Quote Link to comment Share on other sites More sharing options...
BenGoble Posted April 5, 2010 Share Posted April 5, 2010 My first use of lisps and that's damn good mate! Quote Link to comment Share on other sites More sharing options...
asos2000 Posted April 7, 2010 Share Posted April 7, 2010 Spacepig Thamks for this great lisp I want to ask you for another lisp if you have. Its about welding symbol. Thanks again for sharing this lisp Quote Link to comment Share on other sites More sharing options...
