Tharwat Posted April 18, 2012 Posted April 18, 2012 Hello guys. Is it possible to adjust the appearance of a dialog box to become equal in all sides ? The following dialog box needs to adjust the text "X" to be in the middle and the buttons Ok and Cancel to be within the same size . strings: dialog { label = "Window Selection "; :column { :boxed_row {label = "Strings ..."; :column { :row { : text { value = "Width"; } : text { value = "X"; } : text { value = "Height"; } } :row { : popup_list { key = "l1"; width = 10; } : popup_list { key = "l2"; width = 10; } } } } :row { : button { key = "accept"; label = "OK"; fixed_width = false; is_default = true; is_cancel = true; allow_accept =true; } : button { key = "cancel"; label = " Cancel "; fixed_width = false; is_default = false; is_cancel = true;} } } } Quote
MSasu Posted April 18, 2012 Posted April 18, 2012 You can control the size of a dialog by width and height attributes; width works also for buttons and labels. May use spacer tile to adjust the location of other tiles. strings: dialog { label = "Window Selection "; [color=magenta] [color=red] width = 30; height = 12;[/color][/color] :column { :boxed_row {label = "Strings ..."; :column { :row { [color=red]: spacer { width = 2; }[/color] : text { value = "Width"; [color=magenta][color=red]width = 7;[/color] [/color]} : text { value = "X"; [color=red]width = 3;[/color] } : text { value = "Height"; [color=red]width = 5;[/color] } [color=red]: spacer { width = 2; }[/color] } :row { : popup_list { key = "l1"; width = 10; } : popup_list { key = "l2"; width = 10; } } } } :row { : button { key = "accept"; label = "OK"; [color=red]width = 12;[/color] is_default = true; } : button { key = "cancel"; label = " Cancel "; [color=red]width = 12;[/color] is_cancel = true;} } } } The is_default and is_cancel attributes are controlling the behavior of buttons when press , respectively ; both are set to false by default. Those attributes must be unique per dialog definition. Also is a nonsense to add allow_accept to an OK button - you ask it to trigger by himself. Quote
Lee Mac Posted April 18, 2012 Posted April 18, 2012 I would use something like this: mytext : text { fixed_width = true; alignment = centered; } mybutt : button { fixed_width = true; alignment = centered; width = 12; } strings: dialog { label = "Window Selection"; : boxed_column { label = "Strings"; : row { : column { : mytext { label = "Width"; } : popup_list { key = "l1"; width = 15; fixed_width = true; } } : column { : mytext { label = "X"; } } : column { : mytext { label = "Height"; } : popup_list { key = "l2"; width = 15; fixed_width = true; } } } spacer; } : row { fixed_width = true; alignment = centered; : mybutt { key = "accept"; label = "OK"; is_default = true; } : mybutt { key = "cancel"; label = "Cancel"; is_cancel = true; } } } Quote
Tharwat Posted April 18, 2012 Author Posted April 18, 2012 Waww ... both are GREAT Thank you so much gentlemen . Quote
Tharwat Posted April 19, 2012 Author Posted April 19, 2012 Hello guys . How do you use edit format window for Dcl codes ? Thanks Quote
MSasu Posted April 19, 2012 Posted April 19, 2012 I'm afraid that feature works only with AutoLISP code. Excerpt from help: If you select text to be formatted, the selection must contain valid AutoLISP expressions or the formatter will issue an error message. Quote
Tharwat Posted April 20, 2012 Author Posted April 20, 2012 Hello . I am working on another dialog and I feel the widths ' values are not logic at all , so how do they work ? Thanks Quote
Lee Mac Posted April 20, 2012 Posted April 20, 2012 I am working on another dialog and I feel the widths ' values are not logic at all , so how do they work ? What about them do you feel is not logical? A larger width value will result in a wider tile - seems logical enough to me Quote
Tharwat Posted April 20, 2012 Author Posted April 20, 2012 Hi Lee . Actually when I change the width value of any button or popup list or edit boxes , I see nothing changed on the dialog , here is an example . example: dialog { width = 25; height = 10; label = "Lists " ; :boxed_column { label = "Rows"; :row { :edit_box { label = "Number of Rows :" ; key = "rows" ; value = "" ; edit_width = 7 ; } :popup_list { label = "Supply" ; key = "L1" ; width = 5;} } } :boxed_column { label = "Columns"; width = 5; :row { :edit_box { label = "Number of Columns :" ; key = "columns" ; value = "" ; edit_width = 7 ; } :popup_list { label = "Return " ; key = "L2" ; width = 5;} } } :boxed_row { : button { key = "rect" ; label = "Rectangle selction" ; width = 5 ; is_default = true ; is_cancel = true ; } : button { key = "cancel" ; label = "Cancel" ; width = 5 ; is_cancel = true ; } } } Thanks a lot Quote
Lee Mac Posted April 20, 2012 Posted April 20, 2012 The width value must be large enough to accommodate the size of the label for the button, and furthermore, the fixed_width attribute must be set to true, else the tile will expand to fill the available area. Perhaps have a read through some of the DCL tutorials on AfraLISP, and the DCL guide in the Visual LISP IDE Help Documentation; both offer valuable insights surrounding dialog design and tile behaviour. Quote
