cici2012 Posted April 19, 2012 Posted April 19, 2012 I need help 1) To do volume calculations do you have to insert the second surface into the first before you start? 2) When I am inserting the second file there is an error message that points of the same number has been found. This I believe is because all points start from 1 onwards. Is that the problem? Quote
Tyke Posted April 19, 2012 Posted April 19, 2012 You have the two surfaces as separate DTMs, then create a differential DTM in which you identify the original surface and the surface to be used to calculate the volume. In the end you have three DTMs. Quote
