clipper392 Posted April 19, 2012 Posted April 19, 2012 I am trying to mirror a block which has text defined internally. However, the text will not reverse when the block is mirrored. I have read some documentation which said to use MIRRTEXT with a setting of "1". I tried this and it didn't work, are there any other options which allows the block to stay intact and not have to explode it?? Thanks for the help. Quote
ReMark Posted April 19, 2012 Posted April 19, 2012 Forum member eldon posted this response to a similar question. For text in blocks to stay the right way round after mirroring (with MIRRTEXT set to 0), the text HAS to be an attribute. It must not be ordinary text. Quote
clipper392 Posted April 19, 2012 Author Posted April 19, 2012 I created a new block by exploding an existing one. Then I deleted the existing text and recreated the text as an attribute and then recreated my block. Mirrored the new block and the text was correct. Thanks for the help. Quote
ReMark Posted April 19, 2012 Posted April 19, 2012 The credit goes to eldon I just passed it forward. On his behalf...you're entirely welcomed. Quote
