Hi!
I'm so beginner in 3d modeling in Acad. But stiil have questions :)
In attachment file i have basic figure what i would like to achive. if i have somesort of 3d solid and i would like to cut on part of it in angle. What should i do?
And on third figure, how can i make such cuts in 3d solid?
Thanks !
Martin
3d_solid editing.dwg
One option would be to use the SLICE command with the SURFACE option. The angled portion to be removed would be drawn using two lines. Lines that are extruded become surfaces.
Another option, depending on the final shape of the piece is to construct the profile of the object then use the PressPull command to give it a height.
Took a little creative license with your linework to show you a couple of angled cuts in a 3D solid.
