s1ngh Posted April 22, 2012 Posted April 22, 2012 I've created a bunch of lines which are touching each other but I can't seem to close them into a closed polyline area as I am trying to find the area of each individual profile. I have tried moving the grips away and re attaching them, I have also extended all the lines and attempted to retrim them to ensure that they are closed, but none of this works. The Fuzz distance is on 0, but I don't know if I am changing the profile in the unts of millimetres so I am tentative to change this. But I just can't close the profiles. Help. Quote
s1ngh Posted April 22, 2012 Author Posted April 22, 2012 Drawing2.dwg The file which I am using to close a profile I have attached to this message. Quote
Dadgad Posted April 23, 2012 Posted April 23, 2012 I am not sure how they got that way. I couldn't get them to JOIN with PEDIT, FLATTEN or JOIN commands. I used CHANGE & OVERKILL on them, and found that there were a number of doubled up lines, which doesn't help when trying to join objects. Finally I just traced over them and created a brand new closed polyline. Hope this helps you out. Drawing2CLOSED.dwg Quote
ReMark Posted April 23, 2012 Posted April 23, 2012 Overkill reports 56 duplicates deleted and 1 overlapping object deleted. This is a case of poor drafting/CAD technique given the simplicity of the object you have created. Furthermore, one line is identified as NOT being parallel to the UCS. Just how did you go about creating this object? Lastly, since you created the "arcs" using the ELLIPSE command without first resetting the system variable PELLIPSE to a value of "1" you will not be able to use the PEDIT command to join them up with the straight line segments to either side. You need to crack open a book about AutoCAD and do a little studying. Quote
eldon Posted April 23, 2012 Posted April 23, 2012 If you set the display to show a few more decimal places, you can see why matters are awry. The bottom line looks like this Command: idSpecify point: Endpoint of X = 0.00000051 Y = -0.00000022 Z = -0.00000765 Command: ID Specify point: Endpoint of X = 365.03792951 Y = -0.00000022 Z =0.00000400 Once that were sorted out, Bpoly seems like a way to get the Area Quote
Pablo Ferral Posted April 23, 2012 Posted April 23, 2012 This post: http://cadsetterout.com/autocad-tutorials/cad-to-cam-cleaning-up-dwg-files-for-cnc/ Has tips for using Flatten, Overkill, Pedit and Fillet zero to create clean geometry for CNC. This post: http://cadsetterout.com/autocad-tutorials/converting-ellipses-to-arcs/ Has a lot of tips for converting Ellipses and splines into polylines. and this post: Includes a tip for using the properties palette to identify the Z position of polyline and spline nodes (Useful if you don't have express tools). http://cadsetterout.com/autocad-tutorials/how-increase-your-productivity-autocad-properties-palette/ I Hope you find some useful information in there! Quote
s1ngh Posted April 25, 2012 Author Posted April 25, 2012 Overkill reports 56 duplicates deleted and 1 overlapping object deleted. This is a case of poor drafting/CAD technique given the simplicity of the object you have created. Furthermore, one line is identified as NOT being parallel to the UCS. Just how did you go about creating this object? I exported from NX and brought it into AutoCAD and just offseted lines to be honest and then joined up where possible with straight lines. I more or less created straight lines only. Lastly, since you created the "arcs" using the ELLIPSE command without first resetting the system variable PELLIPSE to a value of "1" you will not be able to use the PEDIT command to join them up with the straight line segments to either side. so if I used the pellipse command and set it to 1 i should be able to pedit and join them up right You need to crack open a book about AutoCAD and do a little studying. I appreciate your comment saying this, in a way I find this funny also, let me explain. I achieved a city and guilds qualifcation with full marks in every exam, so i guess i only mastered the basics of the course to a good level, I have also wanted to further this by advancing my skills as I know that this is only the fundamentals of what autocad is really capable off See bold for replies, again thank you. Quote
s1ngh Posted April 25, 2012 Author Posted April 25, 2012 This post:http://cadsetterout.com/autocad-tutorials/cad-to-cam-cleaning-up-dwg-files-for-cnc/ Has tips for using Flatten, Overkill, Pedit and Fillet zero to create clean geometry for CNC. This post: http://cadsetterout.com/autocad-tutorials/converting-ellipses-to-arcs/ Has a lot of tips for converting Ellipses and splines into polylines. and this post: Includes a tip for using the properties palette to identify the Z position of polyline and spline nodes (Useful if you don't have express tools). http://cadsetterout.com/autocad-tutorials/how-increase-your-productivity-autocad-properties-palette/ I Hope you find some useful information in there! Legend!!! I did hatch all my sections as I have a series of profiles like the ones which I have attached and i cant hatch all of them, all i wanted was areas. Quote
