Conduit
howdy!
i am working with autocad MEP 2013 and Navisworks 2013. when loading the conduit file into Navis, the conduit and fittings are square. I have adjusted the visual style & display manager, but this has not helped. I need advice on how to get the Navis file look like the DWG file.
thanks.
Are you exporting as a NWC file, or simply opening the DWG file? Try exporting as a NWC file using the NWCOUT command if you're not. That's always the best way.
Yes, i have been opening a DWG file in Navis. Most of the time this has worked, but not so much in 2013. thanks for you help!
So did it work or not? :lol:
Sorry, yes it did work. Thank you very much!:D
