RRS1987 Posted April 28, 2012 Posted April 28, 2012 Hi, I working with one schedule dwg by using table command. I could not able to edit text in a cell while i double click, inside the table cell. But i can edit by using right click method. before it (double click) was working. now i dont know what happend. could someone help to me. Thanks in advance Quote
Dadgad Posted April 28, 2012 Posted April 28, 2012 It sounds like the cell is locked, and so you are unable to edit it. If that is correct, then you will need to unlock the cell before you will be able to edit it. Quote
RRS1987 Posted April 28, 2012 Author Posted April 28, 2012 hi, Thanks for your reply. how to unlock table or cell? one more thing, In the property table not showing the table properties when i select the table in dwg. Thanks once again. Quote
tzframpton Posted April 28, 2012 Posted April 28, 2012 Right-click on the cell to give you more features. Or double click the cell to open the Table Formatting Toolbar, this also has the lock/unlock cell icon. Quote
