Multiple Text Edits
Hi,
I need to edit a copy of a Topo Survey we have had done for some drawings that need to be produced (Trial Holes.)
I need to edit the Gas Valve text which shows as GV on my Topo.
However, there is about 100 of these spread out over a vast distance.
Is there a way I can edit the size of the font for these all together or do I have to do them individually?
I have manged to select them all and put them on to a seperate layer by using the Change Properties Command, but I just dont know how to change the size!!
Thanks for any help in advance.
Daz. :?
Quickselect is I believe the best way to be able to select em all, then bring out properties tab to edit the text height
Thanks for that!!
I also managed to use Match Properties with the Filter Command!!
Such a big help as I just managed to amend over 11,000 seperate text entities in seconds!!
Daz :D
