netman Posted May 1, 2012 Share Posted May 1, 2012 I want to be able to see angles in Dynamic Input with the base line set where I need it to be. In the red is where AC puts the baseline in the DYN command. Is there a way for me to "tilt" the baseline so i can use it in ANY angle, like in the blue? * I am referring to the baseline as where 0 degrees begins* adjusting baseline in DYN.dwg Quote Link to comment Share on other sites More sharing options...
Dadgad Posted May 1, 2012 Share Posted May 1, 2012 You should consider the different available polar tracking options in your settings. Quote Link to comment Share on other sites More sharing options...
netman Posted May 2, 2012 Author Share Posted May 2, 2012 Excellent! I did not know about this. That works out just fine and just in time for a big ol' project tonight. Thanks a heap ol' buddy! Quote Link to comment Share on other sites More sharing options...
netman Posted May 2, 2012 Author Share Posted May 2, 2012 Just another question; How do you all get a Snap Shot of the AutoCAD screen ( like you just did) when you're showing what to look for. I would like to use this when I ask questions but can not figure out how to do it. thank you again....... Quote Link to comment Share on other sites More sharing options...
Dadgad Posted May 2, 2012 Share Posted May 2, 2012 You're welcome, glad that helps you out. I am using this on Vista. ALL PROGRAMS > ACCESSORIES > SNIPPING TOOL. Quote Link to comment Share on other sites More sharing options...
SLW210 Posted May 2, 2012 Share Posted May 2, 2012 Just Print Screen and paste into MS Paint, crop and edit as needed. ALT + Print Screen will copy just the current window. Quote Link to comment Share on other sites More sharing options...
