Hi, I'm new here. I want a lisp file which automatically copy visible content of a drawing and save it to a new dwg file. Is it possible? Please help me.
Welcome to Cadtutor .
wblock command help at all ?
Thanks for your reply. But It will only export the content in Model not in Layout. I want to export both
(defun c:test ( / nfn app fn )
 (vl-load-com)
 (if (setq nfn (getfiled "Choose directory" "c:\\" "dwg" 1))
     (setq fn
       (vla-get-fullname
         (setq *acdoc*
           (cond ( *acdoc* )
             ( (vla-get-activedocument (vlax-get-acad-object)) )
     ) (vla-saveas *acdoc* nfn)
     (vla-save *acdoc*) (vla-saveas *acdoc* fn) (vla-save *acdoc*)
     (cond
       ( (findfile "c:\\Windows\\media\\tada.wav")
         (setq app (vlax-create-object "WMPlayer.OCX.7"))
         (vlax-invoke (vlax-get app 'CurrentPlaylist) 'Appenditem
           (vlax-invoke app 'NewMedia "c:\\Windows\\media\\tada.wav")
         ) (vlax-invoke (vlax-get app 'controls) 'play)
         (vlax-release-object app) (gc)
     (startapp "explorer" (vl-filename-directory nfn))
 ) (princ)
Edited by Lt Dan's legs
boredom
I've updated my code above. I'm assuming you wanted to make a backup of the current drawing..
Thanks all-of you. But they does not fulfill my need. I actually want a lisp which copy all the visible content in the model as well as in Layout (but not that layers and contents which are turned off) and save it to a another drawing.
What about making a list of all Frozen/Off layers, use that list to delete all objects that falls onto that list then wblock
Programmatically that is. :)
Well? I'm ready to write the code for you only if you tell me the filename format or folder path
Have time to play
(defun c:Leaveus ( / aDoc Layers path laylist)
       (setvar 'Expert 5)
      (setq aDoc (vla-get-activedocument (vlax-get-acad-object))
             laylist nil
             path (strcat (getvar 'dwgprefix) "CopyOfFiles" "\\"))
    [i] ;<-- "CopyOfFiles" Folder name for Visible drawings
[/i]         (vlax-for
       itm
          (vla-get-layers aDoc)
      (if (or (eq (vla-get-Freeze itm) :vlax-true)
              (eq (vla-get-LayerOn itm) :vlax-false))
            (setq laylist (cons (vla-get-name itm) laylist))))
       (vl-mkdir path)
      (if (and (= (getvar 'Dwgtitled) 1) laylist)
              [b] (command "_undo" "Mark")
[/b]        (vlax-for layout (vla-get-layouts adoc)
               (vlax-for ent (vla-get-block layout)
         (if (member (vla-get-layer ent) laylist)
                        (vla-delete ent))))
               (command [b]"-wblock"[/b] (strcat   path (getvar 'Dwgname)) "*")
              [b] (command "_undo" "Back")
[/b]                )
HTH
Edited by pBe
