Big_D Posted May 2, 2012 Posted May 2, 2012 Does the insert frame feature in the design ribbon have 1" square tubing? If so, what is it under? If not, can I add it? (Running Inventor 12) Thank you in advance. Quote
JD Mather Posted May 2, 2012 Posted May 2, 2012 If not, can I add it? You can add any profile you need that isn't already in there. Check the Help wiki or Rob Cohee 2010 presentation here http://au.autodesk.com titled something like I Didn't Know Inventor Could do That! near the end of the presentation. Quote
