paisis123 Posted May 2, 2012 Posted May 2, 2012 Hey guys I need some help regarding to make a drawing to be flattened and set to elevation zero. I do have the flatten command from express tools, and that works only to make everything to 2d, but i need a simple script routine to set all objects to elevation zero. This is my current methodology 1. select objects 2. flatten 3. select same objects 4. explode 5. select same objects 6. explode 7. select same objects again 8. In property's, adjust Z axis to 0. I fear that this is too long and bulky, and sometimes it wont work. I also fear that any lisps routines are completely out of my league as i never used them before and my company never really had a need for them, but i am willing to give them a shot if it means that they will save me some time. Quote
ReMark Posted May 2, 2012 Posted May 2, 2012 The topic of flattening geometry to an elevation of "0" has been covered numerous times. You can assign the macro in the link provided below to a button. See post #2 of this thread for the macro. http://www.cadtutor.net/forum/showthread.php?68797-possible-to-have-a-script-to-use-flatten&highlight=flatten Quote
