Ezrider714 Posted May 2, 2012 Posted May 2, 2012 Can anyone name the variable that controls the ltscale of newly drawn objects? Had this at one time, but didn't write it down, now Help seems to indicate, this does not exist? What I need is for all newly drawn lines to have a ltscale of .5 instead of having to change them in the properties window. Thanks Quote
Murph_map Posted May 2, 2012 Posted May 2, 2012 CELTSCALE, Sets the linetype scaling for new objects relative to the LTSCALE command setting. A line created with CELTSCALE = 2 in a drawing with LTSCALE set to 0.5 would appear the same as a line created with CELTSCALE = 1 in a drawing with LTSCALE = 1. Quote
Ezrider714 Posted May 3, 2012 Author Posted May 3, 2012 Sorry that does not set the ltscale for newly created object No matter what the LTSCALE is set to, newly created objects have a ltscale of 1.00 as shown in properties Quote
hazardman Posted May 3, 2012 Posted May 3, 2012 or, when nothing is selected, change the linetype scale in the properties panel to something other than 1...when this is done, all new entities drawn after that will take on that ltscale...same goes for anything else listed in the properties panels...if you change, let say, the colour to somenthing other than ByLayer, new objects will take on that colour....etc... Quote
