Land Desktop 2004 Unable to list points
I have two jobs that I know of where I no longer can list points. Until just recently I had no problem. I went to "Points", List points, and tried all of the options, but no luck. I opened up both of these same jobs on another computer and the same bad result. Does someone have an idea?
Later I used opened the points.mdb file using a sourceforge viewer and see that all of the points are there. But for whatever reason and cannot display a list of points nor can form point groups.
Edited by Digidoug
did you try a check points and add unregistered points or something like that to the drawing?
I had a similar problem where none of my C3D commands would work. I too, would list points and nothing would happen. Turns out that the drawing was saved with basic AutoCad. I had to move everything into a new drawing, which took care of the problem.
I am able to add new points and they show up when I list them, but the older points do not show up in list. What do you mean when you say "unregistered points"?
I tried registering unregistered points and it worked. Thank you for solving my problem.
