therock005 Posted May 5, 2012 Posted May 5, 2012 I have got an old laptop (2004 model) with an old 2GHz cpu and 2GB of ram. Which version should you suggest i would install? Is it possible to go more than 2010? Or is 2010 even going to be demanding? Quote
ReMark Posted May 5, 2012 Posted May 5, 2012 What OS is on the laptop? How much system RAM is installed? Is there a dedicated graphics card or a graphics chip? Quote
therock005 Posted May 5, 2012 Author Posted May 5, 2012 I was on Vista x32, and now i freshly installed Win 8 (Consumer Preview). How do you mean system RAM? I gota total of 2GB DDR-667 Physical Ram, with a generic onboard graphics chip (Intel GMA X3100). Quote
therock005 Posted May 6, 2012 Author Posted May 6, 2012 Isnt there some cad benchmark that can approximate the appropriate version of CAD? Do you think my cad wont go over AutoCAD 2010? Have the later versions been that much heavier? Quote
Dadgad Posted May 6, 2012 Posted May 6, 2012 (edited) To the best of my knowledge the installed sizes of the programs are as follows roughly 2007 500MB 2009 800MB 2011 950MB 2012 1.4GB 2013 1.5GB Edited May 6, 2012 by Dadgad Quote
therock005 Posted May 6, 2012 Author Posted May 6, 2012 (edited) Are you referring to installation sizes? EDIT: How did that angry face icon get there? Weird... Edited May 6, 2012 by therock005 Quote
ReMark Posted May 6, 2012 Posted May 6, 2012 If you think about it anything older than 2010 when run under Windows 8 you'll probably have problems with unless you utilize XP Mode or a separate piece of software called Longbow. Quote
Dadgad Posted May 6, 2012 Posted May 6, 2012 Good point ReMark, certainly would try using RUN THIS PROGRAM IN XP Mode first though, as it would be free if it works. Otherwise Longbow sounds like a real good call. Quote
JD Mather Posted May 6, 2012 Posted May 6, 2012 I am running 2012 on an old Vista 32-bit machine (the processor is actually 64-bit, but the machine was manufactured at the beginning of the 64-bit processors and there were not many drivers for 64-bit, thus the 32-bit OS). It is generally not possible to obtain older releases unless you already have the license or are a student. (the Autodesk student site goes back 3 releases). Quote
Dadgad Posted May 6, 2012 Posted May 6, 2012 I'm running 2013 on an old Vista-32bit machine, and it works fine, when it isn't busy screwing up older drawings. Quote
therock005 Posted May 6, 2012 Author Posted May 6, 2012 I am running 2012 on an old Vista 32-bit machine (the processor is actually 64-bit, but the machine was manufactured at the beginning of the 64-bit processors and there were not many drivers for 64-bit, thus the 32-bit OS). It is generally not possible to obtain older releases unless you already have the license or are a student. (the Autodesk student site goes back 3 releases). Nice point, I've been meaning to ask this, but anyway my university can give me access access to older versions if needed. For the moment I installed 2013 to try and see if it can run, but i encounter some issues. I opted not to install this new Autodesk Fusion 2013 software, and also i unchecked license manager from tools and utilities. Now as soon as i launch i dont get the ribbon menu, and i get greeted by this. Does it matter that i chose not to install the aforementioned, or did something else go wrong in the installation? Can somebody make something from the following errors, and possibly how to fix things? See the end of this message for details on invoking just-in-time (JIT) debugging instead of this dialog box. ************** Exception Text ************** System.InvalidProgramException: Common Language Runtime detected an invalid program. at Autodesk.AutoCAD.Runtime.CommandClass.InvokeWorker(MethodInfo mi, Object commandObject, Boolean bLispFunction) at Autodesk.AutoCAD.Runtime.CommandClass.InvokeWorkerWithExceptionFilter(MethodInfo mi, Object commandObject, Boolean bLispFunction) at Autodesk.AutoCAD.Runtime.CommandClass.Invoke(MethodInfo mi, Boolean bLispFunction) at Autodesk.AutoCAD.Runtime.CommandClass.CommandThunk.Invoke() ************** Loaded Assemblies ************** mscorlib Assembly Version: 4.0.0.0 Win32 Version: 4.0.30319.17379 built by: FXBETAREL CodeBase: file:///C:/Windows/Microsoft.NET/Framework/v4.0.30319/mscorlib.dll ---------------------------------------- Acdbmgd Assembly Version: 19.0.0.0 Win32 Version: 19.0.55.0.0 CodeBase: file:///C:/Program%20Files/Autodesk/AutoCAD%202013/AcdbMgd.DLL ---------------------------------------- System Assembly Version: 4.0.0.0 Win32 Version: 4.0.30319.17379 built by: FXBETAREL CodeBase: file:///C:/Windows/Microsoft.Net/assembly/GAC_MSIL/System/v4.0_4.0.0.0__b77a5c561934e089/System.dll ---------------------------------------- System.Core Assembly Version: 4.0.0.0 Win32 Version: 4.0.30319.17379 built by: FXBETAREL CodeBase: file:///C:/Windows/Microsoft.Net/assembly/GAC_MSIL/System.Core/v4.0_4.0.0.0__b77a5c561934e089/System.Core.dll ---------------------------------------- AdApplicationFrame Assembly Version: 0.0.0.0 Win32 Version: 3.5.19.0 CodeBase: file:///C:/Program%20Files/Autodesk/AutoCAD%202013/AdApplicationFrame.DLL ---------------------------------------- AdWindows Assembly Version: 3.5.21.0 Win32 Version: 3.5.21.0 CodeBase: file:///C:/Program%20Files/Autodesk/AutoCAD%202013/AdWindows.DLL ---------------------------------------- PresentationFramework Assembly Version: 4.0.0.0 Win32 Version: 4.0.30319.17379 CodeBase: file:///C:/Windows/Microsoft.Net/assembly/GAC_MSIL/PresentationFramework/v4.0_4.0.0.0__31bf3856ad364e35/PresentationFramework.dll ---------------------------------------- WindowsBase Assembly Version: 4.0.0.0 Win32 Version: 4.0.30319.17379 built by: FXBETAREL CodeBase: file:///C:/Windows/Microsoft.Net/assembly/GAC_MSIL/WindowsBase/v4.0_4.0.0.0__31bf3856ad364e35/WindowsBase.dll ---------------------------------------- PresentationCore Assembly Version: 4.0.0.0 Win32 Version: 4.0.30319.17379 built by: FXBETAREL CodeBase: file:///C:/Windows/Microsoft.Net/assembly/GAC_32/PresentationCore/v4.0_4.0.0.0__31bf3856ad364e35/PresentationCore.dll ---------------------------------------- System.Xaml Assembly Version: 4.0.0.0 Win32 Version: 4.0.30319.17379 built by: FXBETAREL CodeBase: file:///C:/Windows/Microsoft.Net/assembly/GAC_MSIL/System.Xaml/v4.0_4.0.0.0__b77a5c561934e089/System.Xaml.dll ---------------------------------------- System.Xml Assembly Version: 4.0.0.0 Win32 Version: 4.0.30319.17379 built by: FXBETAREL CodeBase: file:///C:/Windows/Microsoft.Net/assembly/GAC_MSIL/System.Xml/v4.0_4.0.0.0__b77a5c561934e089/System.Xml.dll ---------------------------------------- PresentationFramework.Aero Assembly Version: 4.0.0.0 Win32 Version: 4.0.30319.17379 built by: FXBETAREL CodeBase: file:///C:/Windows/Microsoft.Net/assembly/GAC_MSIL/PresentationFramework.Aero/v4.0_4.0.0.0__31bf3856ad364e35/PresentationFramework.Aero.dll ---------------------------------------- System.Drawing Assembly Version: 4.0.0.0 Win32 Version: 4.0.30319.17379 built by: FXBETAREL CodeBase: file:///C:/Windows/Microsoft.Net/assembly/GAC_MSIL/System.Drawing/v4.0_4.0.0.0__b03f5f7f11d50a3a/System.Drawing.dll ---------------------------------------- accoremgd Assembly Version: 19.0.0.0 Win32 Version: 19.0.55.0.0 CodeBase: file:///C:/Program%20Files/Autodesk/AutoCAD%202013/accoremgd.DLL ---------------------------------------- Acmgd Assembly Version: 19.0.0.0 Win32 Version: 19.0.55.0.0 CodeBase: file:///C:/Program%20Files/Autodesk/AutoCAD%202013/Acmgd.DLL ---------------------------------------- System.Configuration Assembly Version: 4.0.0.0 Win32 Version: 4.0.30319.17379 built by: FXBETAREL CodeBase: file:///C:/Windows/Microsoft.Net/assembly/GAC_MSIL/System.Configuration/v4.0_4.0.0.0__b03f5f7f11d50a3a/System.Configuration.dll ---------------------------------------- AcWindows Assembly Version: 19.0.0.0 Win32 Version: 19.0.55.0.0 CodeBase: file:///C:/Program%20Files/Autodesk/AutoCAD%202013/AcWindows.DLL ---------------------------------------- AcCui Assembly Version: 19.0.0.0 Win32 Version: 19.0.55.0.0 CodeBase: file:///C:/Program%20Files/Autodesk/AutoCAD%202013/AcCui.DLL ---------------------------------------- PresentationFramework-SystemXml Assembly Version: 4.0.0.0 Win32 Version: 4.0.30319.17379 CodeBase: file:///C:/Windows/Microsoft.Net/assembly/GAC_MSIL/PresentationFramework-SystemXml/v4.0_4.0.0.0__b77a5c561934e089/PresentationFramework-SystemXml.dll ---------------------------------------- WindowsFormsIntegration Assembly Version: 4.0.0.0 Win32 Version: 4.0.30319.17379 built by: FXBETAREL CodeBase: file:///C:/Windows/Microsoft.Net/assembly/GAC_MSIL/WindowsFormsIntegration/v4.0_4.0.0.0__31bf3856ad364e35/WindowsFormsIntegration.dll ---------------------------------------- AcWindows.resources Assembly Version: 19.0.0.0 Win32 Version: 19.0.55.0.0 CodeBase: file:///C:/Program%20Files/Autodesk/AutoCAD%202013/en-US/AcWindows.resources.DLL ---------------------------------------- PresentationUI Assembly Version: 4.0.0.0 Win32 Version: 4.0.30319.17379 built by: FXBETAREL CodeBase: file:///C:/Windows/Microsoft.Net/assembly/GAC_MSIL/PresentationUI/v4.0_4.0.0.0__31bf3856ad364e35/PresentationUI.dll ---------------------------------------- System.Xml.Linq Assembly Version: 4.0.0.0 Win32 Version: 4.0.30319.17379 built by: FXBETAREL CodeBase: file:///C:/Windows/Microsoft.Net/assembly/GAC_MSIL/System.Xml.Linq/v4.0_4.0.0.0__b77a5c561934e089/System.Xml.Linq.dll ---------------------------------------- PresentationFramework-SystemXmlLinq Assembly Version: 4.0.0.0 Win32 Version: 4.0.30319.17379 CodeBase: file:///C:/Windows/Microsoft.Net/assembly/GAC_MSIL/PresentationFramework-SystemXmlLinq/v4.0_4.0.0.0__b77a5c561934e089/PresentationFramework-SystemXmlLinq.dll ---------------------------------------- System.Windows.Forms Assembly Version: 4.0.0.0 Win32 Version: 4.0.30319.17379 built by: FXBETAREL CodeBase: file:///C:/Windows/Microsoft.Net/assembly/GAC_MSIL/System.Windows.Forms/v4.0_4.0.0.0__b77a5c561934e089/System.Windows.Forms.dll ---------------------------------------- ************** JIT Debugging ************** To enable just-in-time (JIT) debugging, the .config file for this application or computer (machine.config) must have the jitDebugging value set in the system.windows.forms section. The application must also be compiled with debugging enabled. For example: When JIT debugging is enabled, any unhandled exception will be sent to the JIT de****** registered on the computer rather than be handled by this dialog box. Quote
therock005 Posted May 21, 2012 Author Posted May 21, 2012 Could it be because i'm running Windows 8 preview? I still havent managed to solve this error, but i found a guy with the simillar message, that also runs Win 8. EDIT: Hmm, i also found this lot, which people say its not supported on win 8 and gives lots of errors... http://worldcadaccess.typepad.com/blog/2012/03/yip-autocad-2013-runs-on-windows-8.html Quote
