Can a 32 bit version of AutoCAD 2012 be installed on a 64 bit mahine?
Can a 32 bit version of AutoCAD 2012 be installed on a 64 bit machine with windows 7 and a 64 bit
version of AutoCAD 2012 on it? It is a network machine.
Thank you,
Yes there is a way!
You can use program called WOW64 , it creates emulator for 32-bit programs to run on operation systems 64-bit.
I myself have never used it so I can't explain exactly
Why would you want both a 32-bit and a 64-bit version of the same program loaded on your computer assuming of course the program, upon installation, doesn't inform you that there is already another copy of the software installed?
I have a bunch of VBA routines that will not work on the 64 bit version of AutoCAD12
so the 32 bit version of AutoCAD is prefered.
My guess is you'll have to uninstall the 64-bit version. Better contact your reseller first.
