Is there any way to colorize different layers randomly?
I wish to assign different colors to different layers.
Please help.
Sunil
One way .....
(defun c:Test (/ i l obj)
 ;;; Tharwat 08. MAy. 2012 ;;;
 (setq i 1)
 (while
   (setq l (tblnext "LAYER" (null l)))
        (entmod
        (subst
          (cons 62 i)
          (assoc 62 (setq obj (entget (tblobjname "LAYER" (cdr (assoc 2 l))))))
          obj
    (if (eq i 255)
      (setq i 1)
      (setq i (1+ i))
Since you are looking to assign the colors randomly, I suggest you to check the DOS_RANDOM function from McNeel's DOSLib pack:
(rem (dos_random) 255)
Eventually it might help, indicating the number of the first color and then a loop with a number of increment.
Another variant
;; * Library DWGruLispLib http://forum.dwg.ru/showthread.php?t=15691       *
;; * _dwgru-Random                                                         *
;; Based vk_RandNum                                                        *
;; Http://www.caduser.ru/forum/index.php?PAGE_NAME=read&FID=23&TID=32763   *
;; * 07.12.2007 version 0001. Revision Vladimir Azarko (VVA)               *
;; * 21.07.2008 version 0002. Revision Vov.Ka                              *
;;               http://forum.dwg.ru/showpost.php?p=798277&postcount=9     *
(defun _dwgru-random (/ modulus multiplier increment)
;;; Generate a random real number between 0 and 1
;;; Use a global variable *DWGRU_SEED*
 (if (not *DWGRU_SEED*)
   (setq *DWGRU_SEED* (getvar "DATE"))
 (setq  modulus     65536
 multiplier 25173
 increment  13849
 *DWGRU_SEED*     (rem (+ (* multiplier *DWGRU_SEED*) increment) modulus))
 (/ *DWGRU_SEED* modulus)
;;; * dwgru-random-range http://forum.dwg.ru/showthread.php?t=15691
;;; * 07/12/2007 Версия 0001.  Редакция Владимир Азарко (VVA)
(defun dwgru-random-range (Minnum Maxnum )
;;; Generate a random number from a specified range of integers
;;; Uses the library _dwgru-Random
;;; Parameters:
;;; Minnum - the smallest integer
;;; Maxnum - the maximum integer
;;; Return: An integer in the range specified
;;; Use:
 (dwgru-random-range 1 256)
 (dwgru-random-range 1 15)
;(- Maxnum (atoi (rtos (* (- Maxnum Minnum) (_dwgru-num-random)) 2 0))) ;_Comment VVA 07.12.2007
;;;Comment VVA http://forum.dwg.ru/showpost.php?p=798277&postcount=9
;;;(- Maxnum (fix (* (- Maxnum Minnum) (_dwgru-random)))) ;_Add VVA 07.12.2007 Так наверное быстрее
(- Maxnum (fix (* (- Maxnum Minnum -1) (_dwgru-random)))) ;;;Vov.ka http://forum.dwg.ru/showpost.php?p=798277&postcount=9
(defun c:Test (/ l obj)
 (while
        (entmod
        (subst
          (cons 62 (dwgru-random-range 1 255))
          obj
Watch out for a zero return from random or (rem) calls.
-David
Using dos_random
(vlax-map-collection
 (vla-get-layers
   (vla-get-ActiveDocument
     (vlax-get-acad-object)
 (function
   (lambda (x)
     (vla-put-Color x (1+ (rem (dos_random) 254)))
Or using my own random & changing the layer's RGB colours:
(vl-load-com)
(defun Random  (seed /)
 (if (not seed)
   (setq seed (if *random:seed*
                *random:seed*
                (setq *random:seed* (getvar "DATE"))))
   (setq *random:seed* seed))
 (setq seed          (rem (+ (* 25173 seed) 13849) 65536)
       *random:seed* seed)
 (/ seed 65536))
(defun c:RandomLayerColour  (/ col)
 (vlax-for lay  (vla-get-Layers (vla-get-ActiveDocument (vlax-get-acad-object)))
   (setq col (vla-get-TrueColor lay))
   (apply 'vla-SetRGB (cons col (mapcar '(lambda (n) (fix (* n 255))) (list (random nil) (random nil) (random nil)))))
   (vla-put-TrueColor lay col))
 (princ))
