vishwaskekane Posted May 9, 2012 Posted May 9, 2012 I am having Plotting Issue in autocad 2011. I have about six printers listed, but when I pick one it immediately resets to NONE. Please help me. Quote
ReMark Posted May 9, 2012 Posted May 9, 2012 You're choosing the plotter/printer via a lisp routine that you have written? If so, post your code so someone here can take a look at it. Quote
Tiger Posted May 9, 2012 Posted May 9, 2012 Hi Vishwaskekane, I have removed your duplicate thread. I assume since you posted that in Bugs And Quirks section that you don't choose the printers via Lisp? Can you print with either of the printers installed from another program such as Word without a problem? Quote
vishwaskekane Posted May 9, 2012 Author Posted May 9, 2012 Sorry this is first time i post some problem. i am new... yes I can print with another programs without problem. problem with only autocad. Quote
ReMark Posted May 9, 2012 Posted May 9, 2012 Can you create a PDF file from within AutoCAD and then have it print? Quote
Tiger Posted May 9, 2012 Posted May 9, 2012 No worries Could it be that the printer you are selecting can't print the paper size that you have selected? Try changing the paper size first, then choose a printer. Quote
vishwaskekane Posted May 9, 2012 Author Posted May 9, 2012 No i cant. i am facing same problem to create PDF also. Quote
ReMark Posted May 9, 2012 Posted May 9, 2012 Try enabling the above and see what happens. Report your results back here. Quote
ReMark Posted May 9, 2012 Posted May 9, 2012 Yes, I would expect that since your image shows that you did not enable the feature I circled in red in my posted image. Please try again. What steps have you taken so far (before posting to CADTutor) to troubleshoot the problem? No sense repeating something you have already tried. Quote
Adamusi Posted May 23, 2012 Posted May 23, 2012 Ithink there some troble with your network or printer is offline. Quote
vishwaskekane Posted May 23, 2012 Author Posted May 23, 2012 i raised this issue to my IT guy. he changed user name. not its work. but i dont get the solution on my problem. Quote
ReMark Posted May 23, 2012 Posted May 23, 2012 Since you did not make the change that I indicated in my post with the image I would not expect the problem to be solved. You know the old saying, "You can lead a horse to water but you can't rip its lips off". Quote
