Goomba Posted May 9, 2012 Posted May 9, 2012 I am trying to show the mass in the weldment cut list table for each item. If you go into the part and update the cut list and then look at the properties of the cut lists items the mass is correct in the cut list table. But when I bring the cut list onto the drawing it seems like all of the mass's have been divided by 8... Any ideas? Quote
shift1313 Posted May 14, 2012 Posted May 14, 2012 thats odd goomba. How many of the item in question are there. Is it exactly by 8? Quote
Goomba Posted May 15, 2012 Author Posted May 15, 2012 Yeah it was exactly by 8 and it doesnt seem to happen to every weldment either.. not sure... too hard basket, I just added another column and manually entered the masses Quote
shift1313 Posted May 15, 2012 Posted May 15, 2012 sometimes you have to go back into the model and right click on the cutlist folder to update it. I cant imagine that would be the case here though. Without actually reproducing the problem im not sure where to start. is it a file you can share? Quote
