urbanledge Posted May 10, 2012 Share Posted May 10, 2012 hay, New to solid works so take it easy on me, I have a model,its basicly a block with a lofted cut in it.6 sketches. I need to scale the lofted cut by itself but cant figure it out. I also tried scaling all the sketches but that didnt work either! thanks in advance Urbanledge Quote Link to comment Share on other sites More sharing options...
JD Mather Posted May 10, 2012 Share Posted May 10, 2012 Why do you need to scale? Make a mistake? If not, it sounds like a Shell feature might be what you are really after. Attach your file here. Quote Link to comment Share on other sites More sharing options...
urbanledge Posted May 14, 2012 Author Share Posted May 14, 2012 Hi, I have a solid box with a lofted cut in it,I want to keep the box the same size and scale the lofed cut up and down to get 10 or so different sizes with out redrawing them all. The lofted cut is over 6 planes 10mm apart. thanks! Quote Link to comment Share on other sites More sharing options...
bhamze Posted May 14, 2012 Share Posted May 14, 2012 I think a design table or multiple configurations would be your best choice. If you can attach files I will show you an example. Quote Link to comment Share on other sites More sharing options...
shift1313 Posted May 14, 2012 Share Posted May 14, 2012 I would typically avoid the Scale command. I would approach this just like Bhamze and do this with different configurations. If you can dimension the 6 different sketches in a way that they relate to one dimension or global variable it will be easier for you. Quote Link to comment Share on other sites More sharing options...
