Good afternoon
Can someone help me figure out my plot size? I can't seem to get it to work.
As you can see in the code below I've tried a few different things. I have a small program from a long time ago that will return values like "User ####". That program indicates the plot size for my particular plotter should be User 1283. (I have no clue where those values come from and regardless of which returned value that I choose my program still wont work). However, no matter what I've tried - I can't get this code to run past the CanonicalMediaLine.
Any possible help?
Option Explicit
Public Sub SetPageLayout()
'On Error GoTo GetErr
Dim pLayoutConfig As AcadLayout
Set pLayoutConfig = ThisDrawing.ActiveLayout
Dim PlotSize As String
PlotSize = "Oce D+ 24x36 (Landscape)" 'or "User 1283" or "Oce_D_+_24x36_(Landscape)"
   pLayoutConfig.RefreshPlotDeviceInfo
   pLayoutConfig.ShowPlotStyles = False
   pLayoutConfig.ConfigName = "MyPLotter"
   pLayoutConfig.StyleSheet = MyCTBFile"
   pLayoutConfig.CanonicalMediaName = PlotSize ' or "Oce_D_+_24x36_(Landscape)" or "User 1283" or "Oce D+ 24x36 (Landscape)"
   pLayoutConfig.PaperUnits = acInches
   pLayoutConfig.CenterPlot = True
   pLayoutConfig.PlotWithPlotStyles = True
   ThisDrawing.ActiveLayout.PlotRotation = ac90degrees
   pLayoutConfig.PlotType = acExtents
   pLayoutConfig.StandardScale = ac1_1
'GetErr:
If Err.Number <> 0 Then MsgBox ("                NO IDEA WHAT HAPPENED THERE" & vbCr & "EITHER TRY AGAIN OR GO HOME AND HAVE A BEER")
MsgBox "            DONE"
'ThisDrawing.Save
Exit_Here:
End Sub
Nevermind! I got it. I need to load all of the CanonicalMediaNames after I select my plotter and then the "UserXXXX" (with no spaces) works well!
Thanks for looking though....:)
