Trying to finish up my VBA page layout macro
Can someone please look this over and tell me where my errors are? I seem to have two of them and I just can't figure them out.
1. Down at my "CopyFrom" lines....The program seems to go through the process but it still sends me to error control
2. No matter how I set my plot rotation, the plot preview window still retains "portrait" when I need it to switch to "landscape".
Option Explicit
Public Sub CreatePageSetup()
On Error GoTo GetErr
'MsgBox "                                        BE PATIENT" & vbCr & vbCr & "THE PAGE LAYOUT SETUP CAN TAKE UP TO 30 SECONDS"
GoGetCanonicalMediaNames
Dim pLayoutConfig As AcadLayout
Set pLayoutConfig = ThisDrawing.ActiveLayout
Dim MyPlotSize As String
MyPlotSize = "User2314" '<---------------- Use PlotPaperSizeNames.dvb to ascertain this value
Dim PaperSpaceLayout As AcadLayout
Dim ModelSpaceLayout As AcadLayout
Dim pPlotConfigs As AcadPlotConfigurations
Set pPlotConfigs = ThisDrawing.PlotConfigurations
Dim pPlotConfig As AcadPlotConfiguration
Set pPlotConfig = pPlotConfigs.Add("SCI 24x36", False)
   With pPlotConfig
       pLayoutConfig.RefreshPlotDeviceInfo
       pLayoutConfig.ShowPlotStyles = False
       pLayoutConfig.ConfigName = "My Plotter"
       pLayoutConfig.StyleSheet = "My CTB"
       pLayoutConfig.CanonicalMediaName = MyPlotSize
       pLayoutConfig.PlotType = acExtents
       pLayoutConfig.CenterPlot = True
       pLayoutConfig.StandardScale = ac1_1
       pLayoutConfig.PaperUnits = acInches
       pLayoutConfig.PlotWithPlotStyles = True
       pLayoutConfig.PlotViewportsFirst = True
       pLayoutConfig.PlotRotation = ac90degrees
   End With
Set ModelSpaceLayout = ThisDrawing.ModelSpace.Layout
ModelSpaceLayout.CopyFrom pPlotConfig
Set PaperSpaceLayout = ThisDrawing.PaperSpace.Layout
PaperSpaceLayout.CopyFrom pPlotConfig
ThisDrawing.Regen acAllViewports
GetErr:
If Err.Number <> 0 Then MsgBox ("UNIDENTIFIED ERROR")
MsgBox "            DONE"
End Sub
Private Sub GoGetCanonicalMediaNames()
Dim PaperSize As String
Dim MediaNames As Variant
Dim i As Integer
MediaNames = ThisDrawing.ActiveLayout.GetCanonicalMediaNames
For i = LBound(MediaNames) To UBound(MediaNames)
If StrComp(ThisDrawing.ActiveLayout.GetLocaleMediaName(MediaNames(i)), PaperSize, vbTextCompare) = 0 Then
ThisDrawing.ActiveLayout.CanonicalMediaName = MediaNames(i)
ThisDrawing.ActiveLayout.RefreshPlotDeviceInfo
End If
Next
'MsgBox i
End Sub
Can anyone give me a hand figuring this out?
Thank you
Mike
