My global line width seems to have defaulted at 0.50 for all plines I draw in all layers. How do I set it back to 0?
When you start to draw the polyline, drop down the options box and set the width there. It will default to that setting. I think that's what you need.
Thanks so much! It worked! You're my hero!!o:)
You're welcome! I had the same problem myself a while back.
you can also set PLINEWID variable to 0
... explode the polyline that has a width factor to make them thin.
