MEP 2013
I have a three point arc, and the custom line type has text that is not only inverted, its backwards.
Any ideas?
I know it has something to do with the arc angle...i just can't figure out what..
Arcs are always drawn counterclockwise, so some linetypes might appear backward.
You can:
1) convert arc to Polyline and revert it (Pedit command has the option "revert")
2) try to put 180 degrees rotation for text in line definition (don't know if its work)
Edit:
MEP 2013
Any ideas?
Hmm... "inverted" and "backwards" might means that your arc has normal vector set to (0.0 0.0 -1.0)
Type
(entget (car (entsel)))
at the command line, hit enter end select the arc. Then post the result.
