I have an exterior elevation that I copied from a previous project and in the course of editing it I deleted it to draw a new one. After x-refing it into the drawing sheet, a hatch pattern showed up that was not seen in model space. I cannot not delete it or even grab it and has conformed to the new boundaries set by the new elevation drawing. How can I delete or turn off?
What layer is this hatch pattern on? Is the layer locked?
I don't know because it doesn't recognize an object. I've tried to find an object in both model space and layout space but nothing is identified. I've tried to switch layers by selecting the hatching but nothing happens. I'm baffled!
Post a copy of the drawing so we can have a look at it. Thanks.
What happens if you do an Erase > All? Is the hatch selected?
Edited by ReMark
Welcome to the forum. :)
Try WIPEOUT > FRAMES > ON.
If you are able to post it somebody will certainly figure it out for you.
I'm pretty curious about this one.
Must have solved it on his own or just gave up. We shouldn't have to beat people into cooperating with us by supplying a DWG file. Why make things difficult? I don't understand. Oh well...onward and upwards. Next!
