Hagen_4 Posted May 16, 2012 Posted May 16, 2012 I am wondering how i can set the application menu so I get a center point on all my new sheets. I don't have a center point when i make a new drawing. And I don't know how to put one in my drawing. Using Inventor LT 2013 Quote
Mefloump Posted May 16, 2012 Posted May 16, 2012 Start a new drawing. Select project new geometry and select center point in the origin. Select Finish Sketch and do a save as "save a copy as template". Call your new drawing as Center point and now when you start with that template, the center point will alredy be projected. Quote
Mefloump Posted May 16, 2012 Posted May 16, 2012 I have Inventor 2010 but if the ribbon has not changed, it should be in the right side of the draw toolbar. Quote
Mefloump Posted May 16, 2012 Posted May 16, 2012 Found it. Thanks for the Help! You're welcome. Quote
