group-ungroup - modification- please... :)
Hi guys,
I found this lisp here on the site. I usually work with groups, and i need some modification to this lisp, if possible. I already added a command, REGROUP - RGP,
and i need a new command ADD TO GROUP - i mean, to add some objects to an existing group - can be the same initial group (the same name), or can be a new group, but this new group not to have inside the old group and only to creat a group that will incorporate the old group and some new objects. Also, to remove objects from an existing group...
Thanks!
Hi guys,
I found this lisp here on the site. I usually work with groups, and i need some modification to this lisp, ....
Where's the lisp code SELFCAD? Would it be better if we can HELP you modify with what you already have? rather than asking questions back and forth till somebody here get it right
First half of the code - cannot attach other way, sorry ....
; Group-UnGroup.Lsp v1.01 (03-30-2011) /by kruuger/            ;
;   Included subroutine:                                       ;
;     jk: -> by kojacek  (http://kojacek.republika.pl/)        ;
;     LM: -> by Lee Mac  (http://lee-mac.com/)                 ;
; History of changes:                                          ;
; 1.00 [03-30-2011] - first release                            ;
; 1.01 [03-31-2011] - fixed object highlight issue (by kojacek);
(vl-load-com)
; FUNCTION SYNTAX:                                             ;
;   - GRP - group selected objects                             ;
;   - URP - ungroup selected objects                           ;
(defun C:GP (/ SS AG)
 (princ "\nSelect object(s) to make an anonymous group: ")
 (if (setq SS (kr:SSX_SS->VLA (ssget)))
     (SETQ SELI SS)
     (vla-AppendItems
       (setq AG (kr:GRP_CreateAnonymousGroup))
       (vlax-Make-Variant
         (vlax-SafeArray-Fill
           (vlax-Make-SafeArray
             vlax-VbObject
             (cons 0 (1- (length SS)))
           SS
     (princ (strcat "\n>> Group " (vla-Get-Name AG) " created. <<"))
   (princ "\n** Nothing selected **")
 (SETQ S SS)
(defun C:XGP (/ OLDERR PIC)  ;EXPLODE GROUP
 (setq OLDERR *error* *error* UGR_Error)
 (if (kr:GRP_GroupList)
     (kr:SYS_StartUndo)
     (setq PIC (getvar 'PICKSTYLE))
     (setvar 'PICKSTYLE 0)
     (kr:UGR_GrreadObjectSelect)
     (kr:SYS_EndUndo)
   (princ "\n** No group(s) in current drawing **")
 (redraw)
 (if OLDERR (setq *error* OLDERR))
 (if PIC (setvar 'PICKSTYLE PIC))
(defun C:RGP (/ SS AG)   ; REGROUP
 (if SELI
     (vla-AppendItems
       (vlax-Make-Variant
             vlax-VbObject
             (cons 0 (1- (length SELI)))
           SELI
; Error handling                                               ;
(defun UGR_Error (msg)
 (if
   (= 8 (logand 8 (getvar "UNDOCTL")))
   (kr:SYS_EndUndo)
 (if
   (or (= msg "Function cancelled")(= msg "quit / exit abort"))
   (princ " *Cancel*")
 (redraw)
; Grread object select                                         ;
(defun kr:UGR_GrreadObjectSelect (/ C GR GD GP EN LST OL)
 (setq C 1)
 (while
     (setq GR (grread nil 13 2)
           GD (cadr GR)
     (redraw)
     (if EN (redraw EN 4))
     (cond
       ( (= 25 (car GR))
         (princ "\n>> End of UGR routine. <<")
         nil
       ( (= 5 (car GR))
         (setq GP (cadr GR))
         (if (setq SS (jk:SSX_SelectByPickBox GP))
             (setq SSL (sslength SS))
             (cond
               ( (= SSL 1)
                 ; --- redraw --- kojacek
                 (setq EN
                   (jk:UGR_RedrawObj
                     (ssname SS 0)
                     (car (nentselp GP))
                 (if (not (zerop (length (setq LST (kr:GRP_GroupNames EN)))))
                     (LM:DisplayGrText
                       GP
                       (strcat
                         "Belongs to group(s) <Exit>: "
                         "\n" (LM:lst->str LST "/")
                       3 8 8
                   (LM:DisplayGrText GP "** Object not belongs to any group(s) <Exit>: **" 2 8
               ( (> SSL 1)
                 (setq EN
                   (jk:UGR_RedrawObj
                     (setq EN (ssname SS (1- C)))
                     (car (nentselp gp))
                 (LM:DisplayGrText
                   GP
                   (strcat
                     "Overlaped object(s): " (itoa SSL)
                     "\nObject selected: " (itoa C)
                   3 8 8
                 (LM:DisplayGrText GP "\n\n+/- Next/Previous object" 94 8
                     (LM:DisplayGrText
                       GP
                       (strcat
                         "\n\n\nBelongs to group(s) <Exit>: "
                       3 8 8
                     (LM:DisplayGrText
                       GP
                       "\n\n\n** Not belongs to any group <Exit>: **"
                       2 8 8
             (setq C 1)
             (setq EN
               (jk:UGR_RedrawObj
                 EN
                 (car (nentselp GP))
             (LM:DisplayGrText GP "Select object to explode group <Exit>: " 1 8
         T
       ( (= 3 (car GR))
         (if (and EN LST)
             (kr:UGR_CommandLineUngroup LST)
             nil
           T
       ( (= 2 (car GR))
         (cond
           ( (or
               (= GD 13)  ; Enter
               (= GD 32)  ; Space
               (= GD 69)  ; E
               (= GD 101) ; e
             nil
           ( (= GD 43) ; +
             (if EN
                 (setq C (1+ C))
                 (if (> C SSL)
                   (setq C 1)
             T
           ( (= GD 45) ; -
             (if EN
                 (setq C (1- C))
                 (if (zerop C)
                   (setq C SSL)
             T
           ( T )
       ( T )
; Redraw selected object (by kojacek)                          ;
(defun jk:UGR_RedrawObj (e n)
 (if n
   (progn (if e (redraw e 3)) e)
   (progn (if e (redraw e 4)) nil)
; Command line ungroup                                         ;
(defun kr:UGR_CommandLineUngroup (Lst / GK)
 (kr:SYS_StartUndo)
 (if (= (length Lst) 1)
     (kr:GRP_DeleteGroupbyName (car Lst))
     (princ (strcat "\n>> Group " (car Lst) " exploded. <<"))
     (initget (strcat (LM:lst->str Lst " ") " All"))
     (setq GK (getkword (strcat "\nEnter group name: [" (LM:lst->str Lst "/") "/All] <All>: ")))
     (if (not GK) (setq GK "All"))
     (cond
       ( (= GK "All")
         (foreach % Lst
           (kr:GRP_DeleteGroupbyName %)
           (princ (strcat "\n>> Group " % " exploded. <<"))
       ( (member GK Lst)
         (kr:GRP_DeleteGroupbyName GK)
         (princ (strcat "\n>> Group " GK " exploded. <<"))
 (kr:SYS_EndUndo)
; LIBRARY FUNCTION                                             ;
; Retrieves pointers to the active document                    ;
(defun kr:ACX_ADoc ()
 (or
   *kr-ADoc
   (setq *kr-ADoc (vla-Get-ActiveDocument (vlax-Get-Acad-Object)))
 *kr-ADoc
And the second half of the code... sorry for the trouble, guys...
; Create anonymous group                                       ;
(defun kr:GRP_CreateAnonymousGroup ()
 (vla-Add
   (vla-Get-Groups (kr:ACX_ADoc))
; Delete anonymous group by name                               ;
;   Name [sTR] - group name to delete                          ;
(defun kr:GRP_DeleteGroupbyName (Name)
 (vl-Catch-All-Apply
  '(lambda ()
     (vla-Delete
       (vla-Item
          Name
; Group list                                                   ;
(defun kr:GRP_GroupList (/ LST)
 (reverse
   (vlax-for %
     (vla-get-Groups (kr:ACX_ADoc))
     (setq LST (cons (vla-Get-Name %) LST))
; Returns a list of group names the ename is a child of,       ;
; innermost first in the list (by Michael Puckett)             ;
;   En [ENAME] - object ename                                  ;
(defun kr:GRP_GroupNames (En / DCT RET)
 (setq DCT (dictsearch (namedobjdict) "acad_group"))
 (while (setq DCT (member (assoc 3 DCT) DCT))
   (if (member (cons 340 En)
     (entget (cdadr DCT)))
     (setq RET (cons (cdar DCT) RET))
   (setq DCT (cddr DCT))
 (reverse RET)
; Convert selection set to a list of VLA objects               ;
(defun kr:SSX_SS->VLA (Sel / N L#)
 (repeat (setq N (sslength Sel))
   (setq N (1- N)
         L# (cons (vlax-Ename->vla-Object (ssname Sel N)) L#)
; Selection set by PICKBOX around point Pt                        ;
(defun jk:SSX_SelectByPickBox (Pt / c pts)
 (setq c
         (getvar "PICKBOX")
           (getvar "VIEWSIZE")
           (cadr (getvar "SCREENSIZE"))
       (sqrt 2)
     ) 2
       pts (mapcar
             (function
               (lambda (%)(trans (polar (trans pt 1 0) (* % pi) c) 0 1))
             (list 0.25 0.75 1.25 1.75 0.25)
 (ssget "_F" pts)
; Start undo mark                                              ;
(defun kr:SYS_StartUndo ()
 (vla-StartUndoMark (kr:ACX_ADoc))
; End undo mark                                                ;
(defun kr:SYS_EndUndo ()
 (vla-EndUndoMark (kr:ACX_ADoc))
;;-------------------=={ List to String }==-------------------;;
;;  Constructs a string from a list of strings separating     ;;
;;  each element by a specified delimiter                     ;;
;;  Author: Lee Mac, Copyright Š 2010 - www.lee-mac.com       ;;
;;  Arguments:                                                ;;
;;  lst - a list of strings to process                        ;;
;;  del - delimiter by which to separate each list element    ;;
;;  Returns:  String containing each string in the list       ;;
(defun LM:lst->str ( lst del )
 ;; Š Lee Mac 2010
 (if (cdr lst)
   (strcat (car lst) del (LM:lst->str (cdr lst) del))
   (car lst)
;;-----------------------=={ GrText }==-----------------------;;
;;  Returns a grvecs pixel vector list relative to the origin ;;
;;  encoding the supplied String.                             ;;
;;  Author: Lee Mac, Copyright © 2011 - www.lee-mac.com       ;;
;;  With thanks to ElpanovEvgeniy for the method of vector    ;;
;;  encoding to save me a lot of typing                     ;;
;;  Arguments:                                                ;;
;;  str - String to be expressed in vector list format.       ;;
;;  col - Colour of Text (ACI Colour).                        ;;
;;  Returns:  GrVecs Pixel Vector List relative to the Origin ;;
;;  Version 1.0    -    19-03-2011                            ;;
(defun LM:GrText ( str col / c i l v y )
   (setq v
     ("\t")
     ("!"   45  45  65 135)
     ("\"" 104 134 107 137)
     ("#"   43  63  46  66  84  94  87  97 115 135 118 138  72  78 103 109)
     ("$"   25  35  52  52  43  47  58  78  83  87  92 112 123 127 118 118 135 135)
     ("%"   52  52  63  63  74  74  85  85  96  96 107 107 118 118 129 129  47  48  67  68  56  56  59  59 113 114 133 134 122 122 125 125)
     ("&"   43  46  49  49  52  72  57  58  67  68  76  76  79  79  83  83  85  85  94  94 103 123 134 136 127 127)
     ("'"  105 135)
     ("("   17  17  26  36  45 105 116 126 137 137)
     (")"   14  14  25  35  46 106 115 125 134 134)
     ("*"   73  74  76  77  84  86  92  98 104 106 113 114 116 117)
     ("+"   55 115  82  84  86  88)
     (","   34  35  45  46  55  57)
     ("-"   83  88)
     ("."   45  46  55  56)
     ("/"   52  52  63  63  74  74  85  85  96  96 107 107 118 118 129 129)
     ("0"   44  47 134 137  53 123  58 128)
     ("1"   44  48 124 125  56 136)
     ("2"   43  48  53  53  64  64  75  75  86  86  97  97 108 128 134 137 123 123)
     ("3"   53  53  44  47  58  88  95  97 108 128 134 137 123 123)
     ("4"   46  48  57 137  78  78  73  76  83  83  94  94 105 115 126 126)
     ("5"   53  53  44  47  58  88  94  97  93 133 134 138)
     ("6"   44  47  58  88  95  97  84  84  53 113 124 124 135 137)
     ("7"   44  54  65  75  86  96 107 117 128 138 133 137 123 123)
     ("8"   44  47  94  97 134 137  53  83  58  88 103 123 108 128)
     ("9"   44  46  57  57  68 128  97  97  84  86 134 137  93 123)
     (":"   45  46  55  56  95  96 105 106)
     (";"   34  35  45  46  55  57  95  96 105 106)
     ("<"   47  47  56  56  65  65  74  74  83  83  94  94 105 105 116 116 127 127)
     ("="   73  78  93  98)
     (">"   43  43  54  54  65  65  76  76  87  87  96  96 105 105 114 114 123 123)
     ("?"   45  45  65  75  86  86  97  97 108 128 134 137 123 123)
     ("@"   34  38  43  43  52 112 123 123 134 137 128 128  79 119  68  68  65  66 105 106  77 107  74  94)
     ("A"   41  43  47  49  52  62  58  68  73  77  83  93  87  97 104 114 106 116 125 135 133 134)
     ("B"   42  47  53 123  58  88 108 128  94  97 132 137)
     ("C"   44  47  53  53  58  58  62 112 123 123 134 136 127 127 108 138)
     ("D"   42  46  57  57 127 127 132 136  68 118  53 123)
     ("E"   42  48  58  58  94  95  86 106 132 137 128 138  53 123)
     ("F"   42  45  94  95  86 106 132 137 128 138  53 123)
     ("G"   44  47  53  53  58  78  86  89  62 112 123 123 134 136 127 127 108 138)
     ("H"   41  43  47  49 131 133 137 139  93  97  52 122  58 128)
     ("I"   43  47 133 137  55 125)
     ("J"   52  62  43  46  57 127 135 139)
     ("K"   42  44  48  49 132 134 136 138  53 123  84  85  95  95 106 116 127 127  76  76  67  67  58  58)
     ("L"   42  47  48  58  53 123 132 135)
     ("M"   41  43  47  49  52 122  58 128 131 132 138 139 103 113 107 117  84  94  86  96  65  75)
     ("N"   41  44 131 132 136 139  52 122  48 128 113 113  94 104  85  85  66  76  57  57)
     ("O"   44  46  53  53  57  57 123 123 127 127 134 136  62 112  68 118)
     ("P"   42  45  84  87 132 137  53 123  98 128)
     ("Q"  134 136 123 123 127 127 112  62 118  68  53  53  57  57  44  46  35  36  23  24  27  28)
     ("R"   42  44  48  49 132 137 123  53 128  98  84  87  76  76  67  67  58  58)
     ("S"   42  62  53  53  44  47  58  78  86  87  93  95 102 122 133 136 127 127 118 138)
     ("T"   43  47  55 125 132 138 131 121 139 129)
     ("U"   44  46  52  53  57  58  62 122  68 128 131 133 137 139)
     ("V"   45  55  64  74  66  76  83 103  87 107 112 122 118 128 131 133 137 139)
     ("W"   43  63  47  67  72  92  74  94  76  96  78  98 101 121 105 115 109 129 131 132 138 139)
     ("X"   41  43  47  49 131 133 137 139  52  52  58  58  63  63  67  67  74  74  76  76  85  95 104 104 106 106 113 113 117 117 122 122 128 128)
     ("Y"   43  47  55  85  94  94  96  96 103 113 107 117 122 122 128 128 131 133 137 139)
     ("Z"  122 122  58  58 132 138  42  48 128 128  52  52  63  63  74  74  85  95 106 106 117 117)
     ("["   15  17 135 137  25 125)
     ("\\" 122 122 113 113 104 104  95  95  86  86  77  77  68  68  59  59)
     ("]"   14  16 134 136  26 126)
     ("^"  102 102 113 113 124 124 135 135 126 126 117 117 108 108)
     ("_"   21  29)
     ("`"  125 125 134 134)
     ("a"   43  46  48  48  52  72  57  97  83  86 103 106)
     ("b"   42  43  45  46  54  54  57  58  68  98  97  97 105 106  94  94 132 132  53 133)
     ("c"   44  46  53  53  57  58  52  92  93  93 104 106  97  98 108 108)
     ("d"   44  45  47  48  52  92  53  53  56  56  93  93 104 105  96  96 136 136  57 137)
     ("e"   44  46  53  53  57  58  52  92  93  93 104 106  97  98  88  88  73  78)
     ("f"   43  46  54 124  93  93  95  96 135 137 128 128)
     ("g"   13  16  22  32  27  97 107 108  66  66  96  96  54  55 104 105  63  63  93  93  62  92)
     ("h"   42  44  46  48  57  97  53 133 132 132  94  94 105 106)
     ("i"   43  47  55 105 103 104 135 135)
     ("j"   22  22  13  15  26 106 104 105 136 136)
     ("k"   42  44  46  48  53 133 132 132  57  57  66  66  74  75  85  85  96 106 107 108)
     ("l"   43  47  55 135 133 134)
     ("m"   41  43  45  46  48  49  52 102  55 105  58 108 101 101  93  93 104 104  96  96 107 107)
     ("n"   42  44  46  48  53 103  57  97 102 102  94  94 105 106)
     ("o"   44  46 104 106  53  53  57  57  93  93  97  97  52  92  58  98)
     ("p"   12  15  23 103 102 102  54  54  94  94  45  46 105 106  57  58  97  98  68  88)
     ("q"   15  18  27 107 108 108  56  56  96  96  44  45 104 105  52  53  92  93  62  82)
     ("r"   42  46  54 104 102 103  95  95 106 108  99  99)
     ("s"   52  52  43  47  58  68  73  77  82  92 103 107  98  98)
     ("t"   45  47  58  58  54 124 102 103 105 107)
     ("u"  102 102 106 106  53 103  56  56  44  45  47 107  48  48)
     ("v"   45  45  54  64  56  66  73  83  77  87  92  92  98  98 101 103 107 109)
     ("w"   43  53  47  57  62  92  64  84  66  86  68  98 101 103  95 105 107 109)
     ("x"   42  44  46  48 102 104 106 108  53  53  57  57  93  93  97  97  64  64  66  66  84  84  86  86  75  75)
     ("y"   12  13  24  24  35  45  54  64  56  66  73  83  77  87  92  92  98  98 101 103 107 109)
     ("z"   92  92  58  58 102 108  42  48  97  97  86  86  75  75  64  64  53  53)
     ("{"   16  17  25  65  73  74  85 125 136 137)
     ("|"   15 135)
     ("}"   14  15  26  66  77  78  86 126 134 135)
     ("~"  112 122 133 134 125 125 116 117 128 138)
 (eval
   (list 'defun 'LM:GrText '( str col / c i l v y )
     (list 'setq 'v
       (list 'quote
         (mapcar
           (function
             (lambda ( b )
               (cons (car b) (mapcar '(lambda ( a ) (if a (list (rem a 10) (/ a 10)))) (cdr b)))
           v
    '(setq i 0 y 0)
      '(repeat (strlen str)
       (cond
         ( (eq (setq c (substr str 1 1)) " ")
           (setq i (+ i 9) str (substr str 2))
         ( (eq c "\t")
           (setq i (+ i 36) str (substr str 2))
         ( (eq c "\n")
           (setq i 0 y (- y 16) str (substr str 2))
         ( (setq l
             (cons
               (mapcar
                 (function
                   (lambda ( a )
                     (if a (list (+ (car a) i) (+ (cadr a) y)))
                 (cdr (assoc c v))
               l
             str (substr str 2) i (+ i 9)
    '(cons col (apply 'append l))
 (LM:GrText str col)
; Display grread text                                          ;
;   Point
[list] - cursor Point in UCS                       ;
;   String   [sTR] - text to display                           ;
;   Color    [iNT] - color of text                             ;
;   Xoffset [REAL] - offset from cursor in +ve x-direction     ;
;   Yoffset [REAL] - offset from cursor in -ve y-direction     ;
(defun LM:DisplayGrText (Point String Color Xoffset Yoffset)
   (lambda (s p)
     (grvecs (LM:GrText String Color)
         (lambda (s x y)
           (list
             (list s  0. 0. x )
             (list 0. s  0. y )
             (list 0. 0. s  0.)
             (list 0. 0. 0. 1.)
         s (+ (car p) (* Xoffset s)) (- (cadr p) (* (+ 16 Yoffset) s))
   (/ (getvar 'VIEWSIZE) (cadr (getvar 'SCREENSIZE))) (trans Point 1 3)
(princ "\n>> Loaded Group-UnGroup.lsp (03-2011) /by kruuger/. Type GRP, UGR to invoke <<")
; jk: -> by [b]kojacek [/b](http://kojacek.republika.pl/) ;
; LM: -> by [b]Lee Mac[/b] (http://lee-mac.com/) ;
; kruuger
; MP
Oh my, I guess we'll let the original author/s take the first crack at it. I bet it wouldnt take them long to figure out what to do. :)
  • 2 weeks later...
Guest kruuger
hi SELFCAD
ooo, old stuff :) i will see what i can do.
i'm a liitle busy last few weeks.
k.
