jsplumber Posted May 17, 2012 Posted May 17, 2012 So I have Revit open with the split vertical viewport option on, but the program is only running in the left view. The right one which is set for 3D is just blank and whenever I try to select that side the 3D viewpops up on the 2D side and will act as if the whole screen is set to 3D. Any suggestions on how to fix this would be greatlyappreciated. Quote
tzframpton Posted May 18, 2012 Posted May 18, 2012 You need to adjust your View Template, V/G, or View Range. Quote
