comcu Posted October 29, 2008 Posted October 29, 2008 Hi, I am having a little problem with code i am working on. i am creating a block, adding attributes then getting the user to pick 2points from this the code inserts the block then adds the width and height to the attributes. the problem is that everytime i run it it keeps adding attributes so if i run it 5times i will have 5 of the same attributes in the same block. I think the simpliest way is to say if block exists dont got to the module that creates the block go to the module that adds the values to the attributes. If ThisDrawing.BlockReference.MyBlock = True then Call AddValuesToAttributes ' module name else call CreateBlock ' module name I know the code above does not work my intention is to clarify (or at least try). Thanks you for taking the time to help, Cheers, Col. Quote
BIGAL Posted October 30, 2008 Posted October 30, 2008 Sounds like your sequence of events is wrong inside your repeat loop and its not resetting to recognise the new block created. Quote
comcu Posted October 30, 2008 Author Posted October 30, 2008 Sounds like your sequence of events is wrong inside your repeat loop and its not resetting to recognise the new block created. BIGAL, I dont think it is wrong sequence i just dont thing i have told it to stop creating the block if one exists? Public OpWidTrue As Long Public OpHghtTrue As Long Public OpWid As Long Public OpHght As Long Public OpStartX As Long Public OpStartY As Long Public XOffset As Double Public YOffset As Double Public LayText As String Public GlassHght As Double Public GlassWid As Double Public startPnt As Variant Public endPnt As Variant Public startPoint(0 To 2) As Double, endPoint(0 To 2) As Double Public TextHghtTrue Public GlassRef As String Public GlassSpec As String Sub seedVariablesCreateGlassAtt() LayText = "Text__HADRIAN" XOffset = UFcreateGlassAtt.TxBxXOffset YOffset = UFcreateGlassAtt.TxBxYOffset TextHghtTrue = UFcreateGlassAtt.TxBxTHght * UFcreateGlassAtt.TxBxVPScale GlassRef = UFcreateGlassAtt.TxBxRef GlassSpec = UFcreateGlassAtt.TxBxSpec End Sub Sub RunProjGlassCalc() UFcreateGlassAtt.Show End Sub Sub CreateAttBlock() Dim blockObj As AcadBlock Dim insertionPnt1(0 To 2) As Double Dim insertionPnt2(0 To 2) As Double Dim insertionPnt3(0 To 2) As Double Dim insertionPnt4(0 To 2) As Double Dim alignmentPoint1(0 To 2) As Double Dim alignmentPoint2(0 To 2) As Double Dim alignmentPoint3(0 To 2) As Double Dim alignmentPoint4(0 To 2) As Double Set blockObj = ThisDrawing.Blocks.Add(insertionPnt1, "GlassCalc") ' Define the attribute definition Dim attributeObj As AcadAttribute Dim height As Double Dim mode As Integer Dim prompt1 As String Dim tag1 As String Dim value1 As String Dim prompt2 As String Dim tag2 As String Dim value2 As String height = TextHghtTrue mode = acAttributeModeVerify ' acattributemodeinvisible __ switch between these for visible and invisible tag1 = "GlassRef" prompt1 = "What is the Glass Ref?" value1 = GlassRef insertionPnt1(0) = TextHghtTrue / 5: insertionPnt1(1) = TextHghtTrue * 3: insertionPnt1(2) = 0 alignmentPoint1(0) = TextHghtTrue / 5: alignmentPoint1(1) = TextHghtTrue * 3: alignmentPoint1(2) = 0 tag2 = "GlassSpec" prompt2 = "What is the Glass SPEC?" value2 = GlassSpec insertionPnt2(0) = TextHghtTrue / 5: insertionPnt2(1) = TextHghtTrue * 1.5: insertionPnt2(2) = 0 alignmentPoint2(0) = TextHghtTrue / 5: alignmentPoint2(1) = TextHghtTrue * 1.5: alignmentPoint2(2) = 0 tag3 = "GlassWid" prompt3 = "What is the Glass Width?" value3 = GlassWid insertionPnt3(0) = TextHghtTrue / 5: insertionPnt3(1) = 0: insertionPnt3(2) = 0 alignmentPoint3(0) = TextHghtTrue / 5: alignmentPoint3(1) = 0: alignmentPoint3(2) = 0 tag4 = "GlassHght" prompt4 = "What is the Glass Height?" value4 = GlassHght insertionPnt4(0) = 0#: insertionPnt4(1) = 0: insertionPnt4(2) = 0 alignmentPoint4(0) = TextHghtTrue * 4.5: alignmentPoint4(1) = 0: alignmentPoint4(2) = 0 ' Create the attribute definition on the block Set attributeObj = blockObj.AddAttribute(height, mode, prompt1, insertionPnt1, tag1, "Ref:" & value1) attributeObj.Alignment = acAlignmentCenter attributeObj.TextAlignmentPoint = alignmentPoint1 attributeObj.Alignment = acAlignmentBottomLeft 'attributeObj.StyleName = "APABEM" Set attributeObj = blockObj.AddAttribute(height, mode, prompt2, insertionPnt2, tag2, "Spec: " & value2) attributeObj.Alignment = acAlignmentCenter attributeObj.TextAlignmentPoint = alignmentPoint2 'attributeObj.StyleName = "APABEM" attributeObj.Alignment = acAlignmentBottomLeft Set attributeObj = blockObj.AddAttribute(height, mode, prompt3, insertionPnt3, tag3, value3 & " x ") attributeObj.Alignment = acAlignmentCenter attributeObj.TextAlignmentPoint = alignmentPoint3 'attributeObj.StyleName = "APABEM" attributeObj.Alignment = acAlignmentBottomLeft Set attributeObj = blockObj.AddAttribute(height, mode, prompt4, insertionPnt4, tag4, value4) attributeObj.Alignment = acAlignmentCenter attributeObj.TextAlignmentPoint = alignmentPoint4 'attributeObj.StyleName = "APABEM" attributeObj.Alignment = acAlignmentBottomLeft ThisDrawing.SendCommand "_ATTSYNC" & vbCr & "NAME" & vbCr & "GlassCalc" & vbCr InsertBlock ' ZoomAll End Sub Sub InsertBlock() ' Define the block 'Dim MyAttTextStr As String Dim blockObj As AcadBlock Dim insertionPnt(0 To 2) As Double insertionPnt(0) = 0 insertionPnt(1) = 0 insertionPnt(2) = 0 'Set blockObj = ThisDrawing.Blocks.Add _ '(insertionPnt, "LEVEL4_ATTBLOCK") '(insertionPnt, "APA013") Dim MyInsertPt As Variant 'MyInsertPt = ThisDrawing.Utility.GetPoint(, vbCr & "Pick insertion point: ") MyInsertPt = startPnt ' Insert the block Dim blockrefobj As AcadBlockReference Myblockrefobj = "GlassCalc" Set blockrefobj = ThisDrawing.ModelSpace.InsertBlock _ (MyInsertPt, Myblockrefobj, 1#, 1#, 1#, 0) GlassRef = GlassRef + 1 'UFcreateGlassAtt.Show GetPointsFromUser End Sub I think i need to write code that if the block exists it only inserts the block, it does not create it? Cheers, Col. Quote
comcu Posted October 30, 2008 Author Posted October 30, 2008 Hi, Played about with it a bit and this seems to work Sub BlockPresentDetector() Dim blockObj As AcadBlock 'Set blockObj = ThisDrawing.Blocks.Add(insertionPnt1, "GlassCalc") On Error GoTo ErrorManager Set blockObj = ThisDrawing.Blocks("A4 Portrait") MsgBox ("block exists") End ErrorManager: MsgBox ("Block Does not exist") End Sub I will incoporate it into the code i have and use it to control the flow of the code. Do you know a better way of doing it as it seems a bit of a hash job? Cheers, Col Quote
