Hi
just new to this
we are using acad 2006 to create drawings and saving them in dxf on 3.5 inch disc
we then import the drawing into winner90 software on our router m/c but get the same response each time on loading - too many lines in iso file-
kind regards
Domo
Welcome to the forum. :)
If you were on a newer version of Autocad I would suggest trying the OVERKILL command which might clean things up a bit for you.
Are you able to post a .dwg file, or a part of one, so that we can see how to help you sort it out?
If you want to post a .dwg, select GO ADVANCED, then MANAGE ATTACHMENTS.
Edited by Dadgad
I'll be interested to hear the outcome of this too, as I use a cnc router....
Overkill is an Express Tool and should be available in 2006 version if Express Tools are installed.
As mentioned, post the dwg file.
