fathihvac Posted May 21, 2012 Posted May 21, 2012 (edited) Hello, I want an autolisp that can make the totol length of lines ,polylines, splines and arcs for layername1, layername2 and layername3.And give the result in a TABLE : length table layer total length layername1 123 layername2 456 layername3 789 THE TABLE.pdf Edited May 21, 2012 by fathihvac Quote
fixo Posted May 21, 2012 Posted May 21, 2012 Try this one from my oldies ;;TotalsToTable.lsp (defun c:TTT ( / acsp adoc col cols data ip l lr lrs num objs row rows sset sub tbl tmp tot) (vl-load-com) (setq adoc (vla-get-activedocument (vlax-get-acad-object)) acsp (vla-get-block (vla-get-activelayout adoc)) ) (if (setq sset (ssget "X" '((-4 . "<OR") (0 . "*LINE") (0 . "CIRCLE") (0 . "ARC") (0 . "ELLIPSE") (-4 . "OR>") (-4 . "<NOT") (0 . "MLINE") (-4 . "NOT>") ) ) ) (progn (setq objs (mapcar 'vlax-ename->vla-object (mapcar 'cadr (ssnamex sset)) ) ) (setq lrs nil) (foreach obj objs (if (not (member (setq lr (vla-get-layer obj)) lrs)) (setq lrs (cons lr lrs)) ) ) (setq data nil) (foreach lr lrs (setq sub (vl-remove-if-not '(lambda (o) (eq (vla-get-layer o) lr)) objs ) ) (setq tot 0) (foreach obj sub (setq tot (+ tot (vlax-curve-getdistatparam obj (vlax-curve-getendparam obj) ) ) ) ) (setq tmp (cons lr tot)) (setq data (cons tmp data)) ) (setq data (vl-sort data '(lambda (a b) (< (car a) (car b)))) ) (setq ip (getpoint "\nPick table position: ")) (if (zerop (setq txh (getvar "textsize"))) (setq txh (getvar "dimtxt")) ) (setq tbl (vlax-invoke acsp 'addtable ip (+ (length data) 2) 2 (* txh 20) (* txh 20) ) ) (vla-put-regeneratetablesuppressed tbl :vlax-true) (vla-setrowheight tbl 0 (* txh 3)) (vla-setrowheight tbl 1 (* txh 2.5)) (vla-settext tbl 0 0 "[url="file://c12;title/"]\\C12;TITLE[/url]") (vla-settext tbl 1 0 "[url="file://c5;layer/"]\\C5;Layer[/url] Name") (vla-settext tbl 1 1 "[url="file://c5;total/"]\\C5;Total[/url] Length") (setq row 2) (foreach x data (vla-setrowheight tbl row (* txh 2)) (vla-settext tbl row 0 (car x)) (vla-settext tbl row 1 (rtos (cdr x) 2 3)) (setq row (1+ row)) ) (vla-settextheight tbl actitlerow (* txh 3)) (vla-settextheight tbl (+ acheaderrow acdatarow) (* txh 2)) (vla-setcolumnwidth tbl 0 (* txh 20)) (vla-setcolumnwidth tbl 1 (* txh 20)) (vla-put-regeneratetablesuppressed tbl :vlax-false) ) (princ "\nNothing selected.") ) (princ) ) (princ "\n Start with: \"TTT\"") (prin1) ~'J'~ Quote
pBe Posted May 21, 2012 Posted May 21, 2012 (edited) Too lazy to write a table rouitne (defun c:TLenAll ( / _length ss e cur data lyn ip txh tbl row) (setq _Length (lambda (en) (vlax-get en (if (vlax-property-available-p en 'Length) "Length" "ArcLength")) )[b][color=blue] Lyns "Layer1,Layer2,Layer3");<---- your layers [/color][/b] (if (setq ss (ssget [color=blue][b] (list[/b][/color] '(0 . "*LINE,ARC") [b][color=blue](cons 8 lyns)[/color][/b]))) [color=darkred][b];;; If the layers are constant, might as well include it here ;;; ;;; (setq ss (ssget '((0 . "*LINE,ARC") ;;; ;;; (8 . "Layer1,Layer2,Layer3")))) ;;; [/b][/color] (progn (repeat (sslength ss) (setq e (vlax-ename->vla-object (ssname ss 0))) (if (setq cur (assoc (setq lyn (vla-get-layer e)) data)) (setq data (subst (list (car cur) (+ (_Length e) (cadr cur))) cur data)) (setq data (cons (list lyn (_Length e)) data)) ) (ssdel (ssname ss 0) ss) ) (setq data (vl-sort data '(lambda (a b) (< (car a) (car b)))) ) (setq ip (getpoint "\nPick table position: ")) (if (zerop (setq txh (getvar "textsize"))) (setq txh (getvar "dimtxt")) ) (setq tbl (vlax-invoke (vlax-get (vla-get-ActiveLayout (vla-get-activedocument (vlax-get-acad-object))) 'Block) 'addtable ip (+ (length data) 2) 2 (* txh 20) (* txh 20) ) ) (vla-put-regeneratetablesuppressed tbl :vlax-true) (vla-setrowheight tbl 0 (* txh 3)) (vla-setrowheight tbl 1 (* txh 2.5)) (vla-settext tbl 0 0 "[url="file://\\C12;Length"]\\C12;Length[/url] Table") (vla-settext tbl 1 0 "[url="file://\\C5;Layer"]\\C5;Layer[/url] Name") (vla-settext tbl 1 1 "[url="file://\\C5;Total"]\\C5;Total[/url] Length") (setq row 2) (foreach x data (vla-setrowheight tbl row (* txh 2)) (vla-settext tbl row 0 (car x)) (vla-settext tbl row 1 (rtos (cadr x) 2 3)) (setq row (1+ row)) ) (vla-settextheight tbl actitlerow (* txh 3)) (vla-settextheight tbl (+ acheaderrow acdatarow) (* txh 2)) (vla-setcolumnwidth tbl 0 (* txh 20)) (vla-setcolumnwidth tbl 1 (* txh 20)) (vla-put-regeneratetablesuppressed tbl :vlax-false) )(princ "\nNo Objects Found:") )(princ) ) Everything else's Fixo code (kudos) Edited May 22, 2012 by pBe FWIW Quote
Tharwat Posted May 21, 2012 Posted May 21, 2012 You can add layers to the list , as many as you want as shown in red into the routine ..... (defun c:Test (/ hgt e inc increment Layers insertionPoint tbl lengths lst r selectionset integer selectionsetname ) (vl-load-com) ;;; Tharwat 21 . May . 2012 ;;; (if (not acdoc) (setq acdoc (vla-get-activedocument (vlax-get-acad-object))) ) (setq hgt (if (zerop (cdr (assoc 40 (setq e (entget (tblobjname "STYLE" (getvar 'textstyle))) ) ) ) ) (cdr (assoc 42 e)) (cdr (assoc 40 e)) ) ) (setq increment -1 [color=red][color=black]Layers [/color][b] '("Layer1" "Layer2" "Layer3")[/b][/color] lengths 0 ) (setq r 1) (repeat (length Layers) (if (setq selectionset (ssget "_x" (list '(0 . "LINE,*POLYLINE,SPLINE,ARC") (cons 8 (nth (setq increment (1+ increment)) layers) ) ) ) ) (progn (repeat (setq integer (sslength selectionset)) (setq selectionsetname (ssname selectionset (setq integer (1- integer)) ) ) (setq lengths (+ (vlax-curve-getDistatPoint selectionsetname (vlax-curve-getEndPoint selectionsetname) ) lengths ) ) ) (if lengths (setq lst (cons (cons lengths (nth increment Layers)) lst)) ) (setq lengths 0) ) ) ) (if lst (setq insertionPoint (getpoint "\n Specify Table Location :")) ) (setq tbl (vla-addtable (vla-get-modelspace acdoc) (vlax-3d-point insertionPoint) (+ (length layers) 2) 2 (* hgt 2.5) (* hgt 2.5) ) ) (setq inc -1) (repeat 2 (vla-setcolumnwidth tbl 0 (* hgt 10.)) (vla-setcolumnwidth tbl 1 (* hgt 10.)) (vla-setrowheight tbl (setq inc (1+ inc)) (* hgt 1.5)) ) (vla-settext tbl 0 0 "Length table") (vla-settext tbl 1 0 "Layer") (vla-settext tbl 1 1 "Length Total") (if lst (foreach x (reverse lst) (vla-settext tbl (setq r (1+ r)) 0 (cdr x)) (vla-setcellalignment tbl r 0 acMiddleCenter) (vla-settext tbl r 1 (rtos (car x) 2)) (vla-setcellalignment tbl r 1 acMiddleCenter) ) ) (princ) ) Quote
Tharwat Posted May 21, 2012 Posted May 21, 2012 @pBe Circles do not have the property Length neither ArcLength my friend Quote
pBe Posted May 21, 2012 Posted May 21, 2012 @pBe Circles do not have the property Length neither ArcLength my friend Yup. forgot to remove that when i saw the OP's list of entiteis only when i realized its not included lines ,polylines, splines and arcs thank you for reminding me Quote
Tharwat Posted May 21, 2012 Posted May 21, 2012 Yup. forgot to remove that when i saw the OP's list of entiteis. thank you for reminding me It's my pleasure Quote
fathihvac Posted May 21, 2012 Author Posted May 21, 2012 Thank you for everybody and you Tharwat. Your code is very helpful for me. But can you modify it to allow the user to make a selection on the part of drawing he want. Quote
Tharwat Posted May 21, 2012 Posted May 21, 2012 Thank you for everybody and you Tharwat.Your code is very helpful for me. But can you modify it to allow the user to make a selection on the part of drawing he want. You're welcome , and I am happy that you satisfied with my codes .. In regard to your question , just remove the highlighted codes form the routine and everything would be OK . ........ (setq r 1) (repeat (length Layers) (if (setq selectionset (ssget [color=red][b] "_x"[/b][/color] (list '(0 . "LINE,*POLYLINE,SPLINE,ARC") (cons 8 (nth (setq increment (1+ increment)) layers)) ..................................... Quote
fathihvac Posted May 21, 2012 Author Posted May 21, 2012 I have already done that but it call a number of selections equal to number of layers for example :"leyer1","layer2" so it make the selection 2 times in each time it filter the selection by the first layer then by the second layer. I want filter the selection in one time Quote
pBe Posted May 21, 2012 Posted May 21, 2012 Thank you for everybody . Guess i mis-understood your request then .. Oh well. Quote
Tharwat Posted May 21, 2012 Posted May 21, 2012 I have already done that but it call a number of selections equal to number of layers for example :"leyer1","layer2" so it make the selection 2 times in each time it filter the selection by the first layer then by the second layer.I want filter the selection in one time You're right , I should change the way that the codes running to meet your new needs . which means more time to spend on the routine . Quote
pBe Posted May 21, 2012 Posted May 21, 2012 I have already done that but it call a number of selections equal to number of layers for example :"leyer1","layer2" so it make the selection 2 times in each time it filter the selection by the first layer then by the second layer.I want filter the selection in one time Can you run that by me again fathihvac? Quote
Tharwat Posted May 22, 2012 Posted May 22, 2012 I have already done that but it call a number of selections equal to number of layers for example :"leyer1","layer2" so it make the selection 2 times in each time it filter the selection by the first layer then by the second layer.I want filter the selection in one time Try it now with its much modifications on it to meet your needs (defun c:Test (/ hgt e inc increment Layers insertionPoint tbl lengths lst result r selectionset integer selectionsetname entities i lays n ) (vl-load-com) ;;; Tharwat 22 . May . 2012 ;;; (setq Layers '("Layer1" "Layer2" "Layer3")) (if (not acdoc) (setq acdoc (vla-get-activedocument (vlax-get-acad-object))) ) (setq hgt (if (zerop (cdr (assoc 40 (setq e (entget (tblobjname "STYLE" (getvar 'textstyle))) ) ) ) ) (cdr (assoc 42 e)) (cdr (assoc 40 e)) ) ) (setq increment -1 r 1 ) (if (setq selectionset (ssget (list '(0 . "LINE,*POLYLINE,SPLINE,ARC") (cons 8 (vl-string-right-trim "," (apply 'strcat (foreach x Layers (setq lays (cons (strcat x ",") lays)) ) ) ) ) ) ) ) (progn (repeat (setq integer (sslength selectionset)) (setq entities (cons (ssname selectionset (setq integer (1- integer))) entities ) ) ) (foreach layer layers (setq i -1) (setq lengths 0) (repeat (length entities) (if (eq (cdr (assoc 8 (entget (setq e (nth (setq i (1+ i)) entities))) ) ) layer ) (setq Lengths (+ (cond ((eq (cdr (assoc 0 (entget e))) "LINE") (distance (cdr (assoc 10 (entget e))) (cdr (assoc 11 (entget e))) ) ) ((eq (cdr (assoc 70 (entget e))) 1) (vla-get-length (vlax-ename->vla-object e)) ) (t (vlax-curve-getDistatPoint e (vlax-curve-getEndPoint e) ) ) ) lengths ) ) ) ) (setq lst (cons (cons Layer lengths) lst)) ) ) ) (if selectionset (progn (foreach o (reverse lst) (if (not (eq (cdr o) 0)) (setq result (cons o result)) ) ) (setq insertionPoint (getpoint "\n Specify Table Location :")) (setq tbl (vla-addtable (vla-get-modelspace acdoc) (vlax-3d-point insertionPoint) (+ (length result) 2) 2 (* hgt 2.5) (* hgt 2.5) ) ) (setq inc -1) (repeat 2 (vla-setcolumnwidth tbl 0 (* hgt 10.)) (vla-setcolumnwidth tbl 1 (* hgt 10.)) (vla-setrowheight tbl (setq inc (1+ inc)) (* hgt 2.5)) ) (vla-settext tbl 0 0 "\\C1;Length table") (vla-settext tbl 1 0 "\\C3;Layer") (vla-settext tbl 1 1 "\\C3;Length Total") (foreach x (reverse result) (vla-settext tbl (setq r (1+ r)) 0 (car x)) (vla-setcellalignment tbl r 0 acMiddleCenter) (vla-settext tbl r 1 (rtos (cdr x) 2 4)) (vla-setcellalignment tbl r 1 acMiddleCenter) ) ) (princ) ) (princ "\n Written by Tharwat Al Shoufi") (princ) ) Quote
fathihvac Posted May 22, 2012 Author Posted May 22, 2012 Great job THARWAT.Thank you very much. Quote
Tharwat Posted May 22, 2012 Posted May 22, 2012 Great job THARWAT.Thank you very much. You're welcome anytime Fathi . I really happy that my codes worked as needed for you . Tharwat Quote
pBe Posted May 22, 2012 Posted May 22, 2012 FWIW: I updated the code at post #3 (princ "\n Written by Tharwat Al Shoufi") Thats your full name tharwat? Quote
fathihvac Posted May 22, 2012 Author Posted May 22, 2012 THANK YOU VERY MUTCH pBe YOUR UPDATED CODE RUNS GREATLY. Quote
Tharwat Posted May 22, 2012 Posted May 22, 2012 Thats your full name tharwat? Yup. I forgot to remove that , and I used to add it when routines being spread in the region only Quote
alanjt Posted May 22, 2012 Posted May 22, 2012 @ Tharwat: Why even bother checking if the object is a line? Just use (vlax-curve-getDistAtParam (vlax-curve-getEndParam )) for all selected objects. Quote
