My work station was recently upgraded to Windows 7, 64 bit, it now frequently crashes Acad, usually when I am saving on exiting a drawing. Bellow is one of many error messages, any ideas? our IT guy is at a loss:-
Problem signature:
Problem Event Name: APPCRASH
Application Name: acad.exe
Application Version: 24.0.309.0
Application Timestamp: 4bcbe2a9
Fault Module Name: StackHash_9a0b
Fault Module Version: 6.1.7601.17725
Fault Module Timestamp: 4ec4aa8e
Exception Code: c0000374
Exception Offset: 00000000000c40f2
OS Version: 6.1.7601.2.1.0.256.48
Locale ID: 2057
Additional Information 1: 9a0b
Additional Information 2: 9a0b8e6e32f562d4274362daf3794b40
Additional Information 3: 9dd6
Additional Information 4: 9dd61a7a205b3fd0113f4fc4059f4a26
could be it dont like windows 7 64 bit did you check if it is compatable with autocad help desk ?
You're quite right, it doesn't list Windows 7 on the 2010 disc, but I have tried a 30 day trial of 2013 and it crashes just the same.
are you installing the 64bit version or the 32bit ? I dont have a 64 bit machine so I am not alot of help here m8 but I think it might be that you do need to install the right version
The fact you are crashing using 2 different versions means to me that its more then likely a windows 7 problem but what the problem is I cant help you with other then to try to maybe a reinstall of windows 7 might correct the problem ?
If all fails go back to your old version of windows vista or what ever it was,if it still crashes then it will have to be a hardware problem.
