I am currently writing a program to calculate the weight of a material.
I am having it use the area command. I don't know how to get that information after I run the command. I have it set up to prompt for points just like the area command. So, you choose your points and lets say the area command would normally return with Area = 9.000, Perimeter = 12.000. How can I use that information after I run the command in my program?
Basically:
(command "area" p1 p2 p3 p4 p1 "")
Then I am multiplying the area by the thickness and then multiplying by .2835.
I need to pull the area info so I can complete my formula (area * thickness * .2835)
Also, Can I run the area command and let it get the user points like normal and then go back to my formula in the program? I am kinda new to this so im not sure.
thanks
im sorry figured it out. (getvar "area") ... so simple... why could I have typed that an hour ago :(
(command "area")
(while (= (logand (getvar "cmdactive") 1) 1)
                 (command pause)
(apply '* (list (getvar 'area) thickness 0.2835))
thanks, I couldn't get that exactly to work, but got this:
(defun C:lbs (/ wgt thk)
 (command "area")
                 (command pause)
 (setq thk (getreal "\nEnter thickness: ")
       wgt (* (* thk (getvar "area")) 0.2835)
 (prin1 wgt)
