hi,
before rendering the program write:
make sure destination directory is writable and that the disk is not full. rendering aborted.
how could i find out where is error.
thanks
Do you have enough freespace on your hard drive?
i should have. unfortunately, i do not know, where autocad save temporary render or its way.
Is it in MyDocuments? Where do you save your drawing files?
so the folder is similar with saved autocad .dwg file?
I don't recall. I'll have to do a test render then get back to you with an answer.
