alijahed Posted May 24, 2012 Posted May 24, 2012 Hi All, I designed Part1.ipt and created drawing1.idw. Then I modified Part1.ipt and saved it. In this respect, I've noticed that Inventor keeps the old versions in an 'old' folder in the same root directory. After that I opened the drawing1.idw. Obviously, Part1 on the drawing1.idw automatically updated. Then I saved it as drawing2.idw. In this case if you open drawing1.idw later, it will update itself with the modified version of Part1.ipt which I do not want this happen. How can I stop it or address Inventor to the old Part1.ipt which exist on 'old' folder in the same root? Cheers Ali Quote
Bishop Posted May 24, 2012 Posted May 24, 2012 Save part1.ipt as a different file name before you make changes to it. Quote
Denimoth Posted May 24, 2012 Posted May 24, 2012 By saving the part file to another name, doesn't that mean you have to redo the drawing.idw, including redimensioning everything? Quote
Bishop Posted May 24, 2012 Posted May 24, 2012 Save the drawing under a different file name as well, then Manage Tab --> Replace Model Reference. Quote
JD Mather Posted May 24, 2012 Posted May 24, 2012 You could also Defer Updates on the drawing (of course, before changinng the part file). Quote
alijahed Posted May 28, 2012 Author Posted May 28, 2012 Thanks. Your solution is the one. This is how I went through, opened the drawing1, using Manage Tab --> Replace Model Reference then addressed to part1 in 'old' folder in the root directory. Cheers Ali Quote
