teknomatika Posted November 23, 2012 Posted November 23, 2012 Lee, I changed the routine to also draw the points so random in the plane Z. My question is whether the variable range is well stated. (defun pointsphere (c r / a b p ) (setq a (acos (1- (* 2.0 (LM:rand)))) b (* (LM:rand) (+ pi pi)) ;;p (list (* r (sin a) (cos b)) (* r (sin a) (sin b)) 0.0);;original 2d points;; [color="red"]p (list (* r (sin a) (cos b)) (* r (sin a) (sin b)) (fix (1+ (* (LM:rand)range))));;change to 3d points[/color] ) (entmake (list '(0 . "POINT") (cons 010 (mapcar '+ c p)) (cons 062 (fix (1+ (* (LM:rand) 254)))) (cons 210 p) ) ) ) ;; Rand - Lee Mac ;; PRNG implementing a linear congruential generator with ;; parameters derived from the book 'Numerical Recipes' (defun LM:rand ( / a c m ) (setq m 4294967296.0 a 1664525.0 c 1013904223.0 $xn (rem (+ c (* a (cond ($xn) ((getvar 'date))))) m) ) (/ $xn m) ) ;; ArcCosine - Lee Mac ;; Args: -1 <= x <= 1 (defun acos ( x ) (if (<= -1.0 x 1.0) (atan (sqrt (- 1.0 (* x x))) x) ) ) (defun c:cirp ( / [color="red"]range[/color] c r x ) (if (and (setq x (getint "\nNumber of Points: ")) (setq c (getpoint "\nCenter: ")) (setq r (getdist "\nRadius: " c)) [color="red"](setq range (getint "\nRange Z Coords : "))[/color] ) (repeat x (pointsphere (trans c 1 0) r)) ) (princ) ) Quote
Lee Mac Posted November 23, 2012 Posted November 23, 2012 I changed the routine to also draw the points so random in the plane Z. The points were already 3D, represented by spherical coordinates; you can vary the radius to generate random points inside the sphere: (setq a (acos (1- (* 2.0 (LM:rand)))) b (* (LM:rand) (+ pi pi)) [color=red] r (* (LM:rand) r)[/color] p (list (* r (sin a) (cos b)) (* r (sin a) (sin b)) (* r (cos a))) ) Quote
teknomatika Posted November 23, 2012 Posted November 23, 2012 The points were already 3D, represented by spherical coordinates; you can vary the radius to generate random points inside the sphere: (setq a (acos (1- (* 2.0 (LM:rand)))) b (* (LM:rand) (+ pi pi)) [color=red] r (* (LM:rand) r)[/color] p (list (* r (sin a) (cos b)) (* r (sin a) (sin b)) (* r (cos a))) ) Lee, Ah, ok. Had not seen this possibility. However, my change corresponds to that i need: A definition of the maximum value of Z coordinates, and that the final result is in the form of a circular slice. Tanks again! Quote
teknomatika Posted May 23, 2013 Posted May 23, 2013 The points were already 3D, represented by spherical coordinates; you can vary the radius to generate random points inside the sphere: (setq a (acos (1- (* 2.0 (LM:rand)))) b (* (LM:rand) (+ pi pi)) [color=red] r (* (LM:rand) r)[/color] p (list (* r (sin a) (cos b)) (* r (sin a) (sin b)) (* r (cos a))) ) Lee, greetings. if possible, when you have availability, I would be grateful if you could integrate in this routine an option to be able to draw in a rectangular shape. Thank you. I'll be waiting. Quote
Lee Mac Posted May 23, 2013 Posted May 23, 2013 an option to be able to draw in a rectangular shape. Simply generate random points in all three axes: (defun c:test ( / d n x y z ) (if (and (setq n (getint "\nNumber of Points: ")) (setq d (getcorner '(0.0 0.0) "\nSpecify Base Dimensions: ")) (setq z (getdist '(0.0 0.0) "\nSpecify Height: ")) (setq x (abs (car d)) y (abs (cadr d)) ) ) (repeat n (randrect x y z)) ) (princ) ) (defun randrect ( x y z ) (entmake (list '(0 . "POINT") (list 10 (* (LM:rand) x) (* (LM:rand) y) (* (LM:rand) z)))) ) ;; Rand - Lee Mac ;; PRNG implementing a linear congruential generator with ;; parameters derived from the book 'Numerical Recipes' (defun LM:rand ( / a c m ) (setq m 4294967296.0 a 1664525.0 c 1013904223.0 $xn (rem (+ c (* a (cond ($xn) ((getvar 'date))))) m) ) (/ $xn m) ) I'm sure you could have worked this out Quote
teknomatika Posted May 23, 2013 Posted May 23, 2013 Simply generate random points in all three axes: (defun c:test ( / d n x y z ) (if (and (setq n (getint "\nNumber of Points: ")) (setq d (getcorner '(0.0 0.0) "\nSpecify Base Dimensions: ")) (setq z (getdist '(0.0 0.0) "\nSpecify Height: ")) (setq x (abs (car d)) y (abs (cadr d)) ) ) (repeat n (randrect x y z)) ) (princ) ) (defun randrect ( x y z ) (entmake (list '(0 . "POINT") (list 10 (* (LM:rand) x) (* (LM:rand) y) (* (LM:rand) z)))) ) ;; Rand - Lee Mac ;; PRNG implementing a linear congruential generator with ;; parameters derived from the book 'Numerical Recipes' (defun LM:rand ( / a c m ) (setq m 4294967296.0 a 1664525.0 c 1013904223.0 $xn (rem (+ c (* a (cond ($xn) ((getvar 'date))))) m) ) (/ $xn m) ) I'm sure you could have worked this out Lee, I am most grateful for more this. Even tried to get a solution, but my knowledge is still basic. But slowly .... Tanks! Quote
