Hi Guys ....
Have a Good day
i need to find the selected object is on locked Layer or not
what is the DXF code for Locked layer ...
Please Help
The lock state of the layer is stored on DXF code 70 as bit 2 (value = 4).
o need a program that find to layer is locked or not can do it for me please
:roll:
When you select the said object the lock/un-lock status of his layer is visible in layers pop-up list; not sure what a dedicated routine will do better than this built-in feature.
I Created a small Lisp that Works for change selected object color .......
if i select a locked objects my lisp is not working its showing error .....
so i want to filter only unlocked layer objects
dxf code 72 is showing 0 valuse (72. 0) .......please help
Please post your code.
maybe you can use this:
(setq L (tblnext "layer" T))
(while L
 (if (/= 4 (logand 4 (cdr (assoc 70 L))))
     ;;; your stuff here ;;;
 (setq L (tblnext "layer"))
(while L
Look, we're trying to help you... The code you posted does not do any this:
... So, maybe you can post the code you're having trouble with instead? :)
eeh, I'm trying to help the OP??
(defun c:ccl ()
 (prompt "\nSelect Object(s) To Change Color")
 (if (setq sset (ssget))
     (if (setq nwcol (getint "\nEnter New Color:"))
  (setq cntr 0)
  (repeat (setq len (sslength sset))
    (setq ssnm (ssname sset cntr))
    (setq ent (entget ssnm))
    (if	(= (cdr (assoc 62 ent)) nil)
      (command "chprop" sset "" "c" nwcol "")
	(entmod (subst (cons 62 nwcol) (assoc 62 ent) ent))
	(setq cntr (1+ cntr))(princ)
 )(princ)
:rofl:
My mistake... I posted too quickly. Sorry for MY confusion. :oops:
Command: ccl
Select objects: Specify opposite corner: 1 found
Select objects:
Enter New Color:2
Unknown command "C". Press F1 for help.
2
Unknown command "CCL". Press F1 for help.
This will do the trick:
(defun c:ccl ()
  (setq cntr 0)
    (and
      (/= 4 (logand 4 (cdr (assoc 70 (tblsearch "LAYER" (cdr (assoc 8 ent)))))))
 ) (princ)
(defun c:CCL () (c:ChangeColor))
(defun c:ChangeColor  (/ *error*)
 (vl-load-com)
 (princ "\rCHANGECOLOR ")
 (defun *error*  (msg)
   (and oldNomutt (setvar 'nomutt oldNomutt))
   (if acDoc (vla-endundomark acDoc))
   (cond ((not msg))                                                   ; Normal exit
         ((member msg '("Function cancelled" "quit / exit abort")))    ; <esc> or (quit)
         ((princ (strcat "\n** Error: " msg " ** "))))                 ; Fatal error, display it
   (princ))
 ((lambda (acDoc oldNomutt / ss color)
    (vla-startundomark acDoc)
    (if (and (princ "\nSelect Object(s) To Change Color: ")
             (setvar 'nomutt 1)
             (setq ss (ssget [color=red]"_:L"[/color]))
             (princ "\nSpecify a new object color: ")
             (setq color
                    (acad_colordlg
                      (cond
                        ((= "BYLAYER" (setq color (getvar 'cecolor)))
                         1)
                        ((atoi color)))
                      nil)))
        (vlax-for x (setq ss (vla-get-activeselectionset acDoc))
          (vla-put-color x color))
        (vla-delete ss)
        (*error* nil))
      (cond (ss (*error* "No color selected"))
            ((*error* "Nothing selected")))))
   (vla-get-activedocument (vlax-get-acad-object))
   (getvar 'nomutt)))
wow !!! its working perfectly ...than you and hugs hemuni
is there any option to show which layer is locked ...hmmmm
 (vl-load-com)
   (princ))
             (setvar 'nomutt 1)
             (setq ss (ssget "_:L"))
             (setq color
                    (acad_colordlg
                      (cond
                         1)
                        ((atoi color)))
                      nil)))
        (vla-delete ss)
        (*error* nil))
   (getvar 'nomutt)))
Renderman that was awesome code editing by you .........
now i got what i exactly need ...its filtering only unlocked layer objects
:D:D:D:D
:D:D:D:D
That is kind of you to say; happy to help. :)
So, finally you were looking for a way to filter out items in locked layers from your selection - may be useful for you to check this post for more information on SSGET filters.
