I'm looking for a way to turn of front- and backclipping from lisp.
It seems all the system variables for this are read only.
I have a working routine scripting the dview command, but it requires me to call up the dviewblock and i was hoping for a cleaner solution.
Does anybody know how to access these settings?
You can use the same command call to turn viewport(s) on and off .
I am not looking to turn of viewports?
I don't think that I got what you mean , but I think you can use the command call (-vports) in sequence into lisp .
Can you explain more deeply ? :)
I want to turn of frontclip and backclip without using the dview command.
Clipping is used in the dview command to hide unwanted geometry:
So is that ( front clip ) represent an object e.g Polyline , line , circle ... etc ?
i guess the OP meant "RESET" the view
Will Dview work for you? guess you need a selection to prevent the "house" from appearing. then you can specify "off" on clip options.
Not sure though, its been like ages since i worked on 3D stuff. ;)
Something like.
(command "_Dview" (ssget) "" "_clip" "_off" "")
The only way that I've found is through (command "_.DVEIW" ....) sequence.
You may be able to use (command "_.DVIEW" (entlast) "" ....) and not have the dviewblock appear.
The same goes for camera and target. Sorry -David
Bentley Prosteel has a function that turns off the clipping, so I'm sure there is another way.
Something like.
No this will not work as an empty selection is not allowed.
using entlast is a good workaround, thanks!
Oh, silly me, now why would i think that ssget will not produce a non-empty selection.
Yeah (entlast) is a better option :thumbsup:
And that would be by the use of command Dview :D
Why, would you prefer i used -vports? :facepalm:
I'm still looking for a better solution if anybody knows a way?
:lol:
For saved Views, the Clipping can be altered by modifying the 43, 44 & 71 DXF Group Code Values of the relevant View Table Entity; reference: http://docs.autodesk.com/ACD/2011/ENU/filesDXF/WS1a9193826455f5ff18cb41610ec0a2e719-7a49.htm
Example to turn front clipping off for a given View (refer VIEWMODE Sys Var):
(defun _TurnOffFrontClipping ( view / vmod )
   (if (setq view (tblobjname "VIEW" view))
       (setq view (entget view)
             vmod (assoc 71 view)
             view (entmod (subst (cons 71 (boole 2 (cdr vmod) 2)) vmod view))
Call:
(_TurnOffFrontClipping "YourView")
However, I do not know that there is a way to access the View Entity associated with the unsaved current Modelspace View :unsure:
  • 5 weeks later...
Most people who work in 3D use multiple viewports in model space. So I am sure that the responses that you received are addressing that.
(defun c:unclip()
(getpoint "\nSelect Viewport To Turn Off Clipping: ")
(setvar "highlight" 0)
(command "dview" "" "cl" "off" "")
);end defun c:unclip
