SMP Posted May 30, 2012 Posted May 30, 2012 I must have changed a setting or hit a button with out knowing what i did. Before if i moused over a mulitple segmented poly line while in the fillet command it would 'highlight' that entire length of polyline. Now, all of a sudden, when i am in the fillet command and i mouse over a similar polyline it seems to only highlight the individual segments within the polyline?? But when i leave the fillet command, and mouse over, it will highlight it as one long segment? This is weird. Quote
Blackfish Posted May 31, 2012 Posted May 31, 2012 I think it's 'normal', not weird, AutoCAD behavior. It shows the exact line you are going to fillet. You probably have recently update your software, because in previous releases it was as you describe, it highlights the whole polyline. Get used to it. As far I know there is no setting for it. Quote
